Question about Sony Playstation 3 (PS3) Console
How can I fix my PS3 myself? I don't want to rush and send it to Sony service. I was experiencing difficulties sometimes with the console not reading Games, but It worked sometimes. Now, it is just not reading any game cd.
  • Sony Master
  • 2,200 Answers
Hi
This is a known problem with these units and is caused by a fault which develops in the bluray lens. Sometimes you can resolve it by gently cleaning the lens with a Q-Tip and isopropyl alcohol but most often the lens itself will need replacing.
I have included this excellent walk-through on how you can do this yourself. Please be sure the console is disconnected from the mains supply before carrying out any of this type of work.
Thanks for using FixYa
Posted on Nov 14, 2009
  • 400 Answers
I'd try using a CD lens cleaner, and failing that, see about replacing the drive itself.
Dropped PS3 it turns on for second then it turns off no red or yellow light
It seems that your PS3 hard drive or motherboard may have problems. But sometimes it is not a real hardware failure - May be cable or CPU bad contacts or some minor cases you can fix it.
But you may be ask : Can I really can fix it?
Yes! I found a secret PS3 Repair Guide - It show you how to open your game console, take out those parts, fix the CPU and cables and some more cool tips. Don't need to send your concole to repair. You really can learn the repair skills for further use.
Don't miss it : http://ps3fix.uurl.info
Nov 17, 2011 | Sony Playstation 3 (PS3) Console
My ps3 wont read gamesbut as no problem with dvds
This sounds like a hardware issue. The laser diode that reads the blu-rays has probably died. It will need to be serviced by Sony. (The PS3 has separate laser diodes that read DVDs and Blu-Rays. One or both can go bad)
Although, you can try a couple of things before sending it in.
[url=http://us.playstation.com/support/answer/index.htm?a_id=278][b]Restore settings[/b][/url]
[url=http://us.playstation.com/support/answer/index.htm?a_id=1488][b]Go into safe mode & restore File System[/b][/url]
If those two don't work, you might have to send it in.
Jul 30, 2011 | Sony Playstation 3 (PS3) Console
My game disc is stuck inside the console and the red light blinks sometimes sometimes it will not go on at all
PS3 disc stuck inside the console and leave red light blinks - That means there are many errors in PS3 console. Hard disk problem, motherboard problem or blu-ray drive error are the main cause! But don't send somewhere to repair yet - You CAN fix it by yourself after you read below :
Remember, you are not the only one to suffer this problem! Because I had help so many people to fix the same problem now. You are so lucky to be there. I share a guide for you - It make me like a pro to help my friends and many people. It is too expensive to send back to Sony repair if your machine is out of warranty!
I had solved many PS3 problems after bought this guide. Not only you can fix the red/yellow light blinking problem, it also contains many PS3 hardware fixing solutions too! The author of the guide is a genius and really kind and helpful to his customers. When you have learned the skills, you can help your friends too! Now go to buy it and share what you have learned !
>> PS3 Completed Fixing Guide <<
Jul 09, 2011 | Video Game Consoles & Games
Unable to recognize disk tryed restoring back to default settings
The disc reading problem is quite a big one! It happens because of config settings or if you have checked this then you need to readjust the laser.
It is about a 4/10 in difficulty but you will need to use a good PS3 Repair guide - or of course you can send it in and get it fixed.
I hope this helps?
Jun 27, 2011 | Sony Playstation 3 (PS3) Console
When i put ma ps3 on it goes green yellow red
I experienced the same issume before. This is called Yellow Light of Death or (YLOD)
Please see below on some information regarding this issue and some possible reslotion to prevent this from happening:
If we go by Sony's definition then having PS3 YLOD means "general hardware failure". So it means that a fault could have occurred anywhere in your Console. Don't be afraid though, since most of the times PS3 YLOD is due to motherboard getting detached.
Tips on how to fix it:
Alternatively you can try to repair ps3 YLOD yourself. There are a couple of things you can try to fix YLOD - check for any loose connections since some connections might be loose, you can also try switching it off for around 30 mins and switch it on again. This will help in cooling your PS3 down.
If these tricks don't work, then I will suggest you go through a dedicated PS3 repair guide instead of tinkering on your own. Such guide will cost you almost nothing in comparison to what Sony charges. And, god forbid, if it happens again you can solve the problem for free.
One of the greatest thing about doing it yourself is that you don't have to pay hefty charges to the big companies. Also, you don't have to wait for weeks, you'll completely fix ps3 ylod in no more than a few hours. Many people have already successfully fixed yellow light of death and I don't see a reason why you won't be able to do it. If my PS3 has yellow light of death then I won't pay Sony to repair my PS3. I'd rather fix PS3 lights myself.
If all this steps wont work i suggest to call SONY
1-800-345-7669
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
A VERY HELPFUL RATING IS APPRECIATED, Thanks Regards
Nerdierob
Jun 06, 2011 | Sony Playstation 3 (PS3) Console
Disc does not feed into the playstation
When your Experiencing Problems with the PS3 like this you mainly have 2 options to take, I will go through each one now so you know what to do.
Option 1
Send The PS3 to Sony
Almost all problems with the PS3 Sony can fix easily if not they will send you a refurbished model.
Price:
If your in warranty they will not charge you for this repair/replace.
If your out of warranty the Charge will be $150
Waiting Time:
4-6 weeks
Sony Contacts right here
Option 2
The PS3 Repair guide
When your suffering problems with the PS3 its often easy enough to fix it at home with a good ps3 repair guide. There famous for fixing major problems like:
The YLOD - Yellow light of death/ Red light error
The Disk Read error
The Hard disk Corruption error
The Red Screen of death - Serious error
PS3 Freeze up Error
PS3 No Signal Error - no display
FIX All error messages
between $40 - $60
May 25, 2011 | Sony Playstation 3 (PS3) Console
Discs are not reading. everything else seems to work. Internet, pictures,music all work. games and dvds are not showing up at all.
There is no currently fix for this, sadly.
it is the latest update (3.01) thats been screwing peoples Blu-Ray drives badly.
theres only 3 things i can advise you to do.
1. call sony and send it to them so they can fix it (not free).
2. get a new lens and change it yourself.
3 hang in untill sony sends out something that gonna fix it.
and personally im choosing option 3, since its sony who screwed it up, and not me, and i dont feel like paying sony a fee for fixing my ps3 they broke.. but thats just my point of view.
(yes i got the same prob myself)
Oct 04, 2009 | Sony Playstation 3 (PS3) Console
Ps3 disc read error
Sadly there currently is no fix for this problem. I've also had this same problem and contacted Sony about it.
You need to send it in to them to get it serviced. You can do this at:
www.us.playstation.com/Support/PS3
or
uk.playstation.com/help-support/ps3
If your warrenty has expired it will cost around $180.
Jun 21, 2009 | Sony Playstation 3 (PS3) Console
My ps3 game is not downloading but my ps2 game is on my ps3
8001050F - Hardware failure. Cannot update firmware or connect to internet.
If you are experiencing difficulties, try these common solutions for troubleshooting the PLAYSTATION 3.
Reboot the PLAYSTATION 3 system Update the System Software Power-Cycle All Network Equipment Check Your Environment Restore Default Settings If these steps did not help, send your system in for service.
Dec 01, 2008 | Sony Playstation 3 (PS3) Console
WHat is wrong? SHould I send it to SOny or can I do something myself to make it work?
your cd drive is messed up. open up ur system and replace it. if ur not sure how to, have a friend or send it to sony and they shuld fix it.
Mar 28, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
93 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
