Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore refrigerator. Just replaced defrost timer, 2 weeks ago. This corrected the problem of warm refrigerator compartment. Now water puddles forming on top shelf, and in the very bottom. Water is dripping from above from what looks like 2 drain holes. What do I do?
  • cshaugh Nov 14, 2009
    Why is there so much water?
  • Kenmore Master
  • 1,606 Answers
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Nov 14, 2009
  • Mike Smith
    Mike Smith Nov 14, 2009
    When your refrig goes into defrost , there is possibly a cup of water each time , that defrosts off the coils . If the drain hole is not clear and clean , then the defrost water has to go somewhere , so , it goes outward . The 2 holes , is the first place closest to the clogged drain , where it can run to .
I have a Whirlpool refrigerator that has water running down the inside of it. I have to unplug it for 2 days to let it thaw. Then run warm water through it from the freezer. I then wait most of the day to...
the icing problem may be the heater and terminator / or the defrost timer itself . try a manuel defrost and if this corrects the problem then replace the timer . also there is a defrost drain kit that you should replace this will prevent dthe drain freeezing .. hope this helps mm .
Sep 19, 2011 | Refrigerators
I have a Kenmore refrigerator model number 25358685894. The defrost does not working. I have changed the heating element once about a year ago and thought it might be the same issue again. I notice when...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Kenmore Refrigerators
Cools fine then does not
yes sounds like a defrost problem when ice build up in frz compartment area and is not defrosted then air cannot be circulated.. could be a timer (roughly 15.99 to 49.99), heater (39.99-69.00) or defrost thermostat 29.99-49.99 parts only. shouldnt need all this , but this is wahat ait could be labor is roughly 85-165.oo depending were u live and who u use.
Sep 23, 2009 | Maytag Refrigerators
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Problem with kenmore side by side leaking
2 things could be wrong first is you compressor running if is not running you have to check the overload to see if it tripp if it did it will sound like a babys rattle just repl and compressor should kick back on if is running then is you evaporator motor running if is not then check for volatge at the wires if you get 118 then repl your motor. is the unit defrosting is there a lot of ice on the back cover it might not be so 3 thing might be failing 1 timer 2 defrost thermostat 3 heater coil call a tech to have those check out thanks
Oct 09, 2008 | Kenmore 50522 / 50524 Side by Side...
Defrost solution didn't last....
If it does not defrost after turning the timer then the problem is further into the defrost circuit. If it does defrost when you turn the timer and that is the only time it does defrost replace the timer.
Aug 05, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator on the fritz
The defroster is not working. Ice build up prevents cold air from the freezer chest from blowing into the lower part.
The way the defroster works is this: There is a defrost timer, probably found under the refrigerator at the front, that turns on the defroster three times per day or so. That turns on a heater nested among the freezer coils. It keeps heating until the defrost thermostat gets warm; then it quits defrosting.
I think your defrost timer doesn't turn. You can turn it with a screw driver till you hear a click. Now your ice compartment should be defrosting. With ice buildup it may need lots and lots of defrosting. You might not get cooling back into the lower part for awhile, till the ice buildup melts.
By the preceding, you should know if the defrost timer needs replacing.
If you should need to manually defrost the freezer coils, they are, I think, under the floor of the freezer. To defrost them, I'm told, a hair drier works better than boiling water. The defrost thermostat is in there too, a one inch unit with two wires. It should have no continuity warm, closed circuit frozen. If it has open circuit frozen, that would be your problem.
Jun 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 106.7687461 about once a week refrig stop, light still on?
Try to locate the defrost timer. It sounds like the defrost timer has an intermittent fault and is not operating as it should. It should be situated in the compressor compartment. It is a white or black box with a little knob protruding from it. When the motor stops again, try turning the little knob on the timer untill you hear a loud click. The motor should then start running again. If it does, the timer is faulty. Replace it.
Oct 30, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
128 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
