A coworker was using my phone and was playing with the buttons & I can't hear the phone ring now. The red light flashes indicating there is a call, but I can't hear it ring. Also If I want to use the hands free, I can't hear anything but the perason I call c an hear me.
While the call is ringing in, try pressing the up volume button. Maybe he turned the volume off.
Posted on Jan 08, 2008
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Aug 20, 2011 | Plantronics Backbeat 903 Bluetooth...
May 11, 2011 | Panasonic KXDT333 Phone
Red Ring of Death: Red Flashing XBOX 360 Lights Explained
Common Xbox 360 Red Ring Errors
The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error,
follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Here's how to program line ringing:
• go to the voice terminal whose line ringing you want to program
• slide T/P switch toward you
• touch a line button (note red lights)
• touch the button again until correct code appears:
RED ON = Ring
RED FLASH = Delayed Ring
RED OFF = No Ring
• repeat this procedure for each line
• return T/P switch to center position.
Carl
Oct 19, 2010 | AT&T Merlin Plus 820D2 KSU Phone
Dec 26, 2009 | Microsoft Xbox 360 Console
Sep 15, 2009 | Microsoft Xbox 360 Console
Dec 18, 2008 | Microsoft Xbox 360 Console
Nov 10, 2008 | Panasonic KX-T7630 Corded Phone
Jul 17, 2008 | Toshiba DKT-2020 Corded Phone
Sep 26, 2016 | NorStar T7316E Corded Phone
Jun 15, 2015 | NorStar T7316E Corded Phone
461 people viewed this question
I can't seem to find a way to turn the ringer volume on my t7316e phone, any suggestions?
Exactly the same problem - we have had this since install. Volume button makes no difference
I cant seem to get the ringer to work on my T7316E. It's not the volume i tried that. I can pick my ringers and adjust the volume but when a call cames in it just doesn't ring. Please Help Me.
My phone doesn't ring. The red light lights up, but no ringer. Help...very frustrating.
the ringer will not sound
my phone doesnt righ but the red light flash
