Question about Samsung Propel A767 Cell Phone
My phone randomly shuts off, and then when i try an turn it back on, it just show's the at&t emblem for about 15 secs, then it just starts over, i need help please. it wont go to the main phone menu for some reason...
  • 61 Answers
Whenn you phone shuts off randomly it is trying to update itself which means that you prob dont turn your phone off for at least 2-3 min a day so that it gets its daily updates.. i would pull the batttery out of the back of the phone and leave it out for 1-2 min and reinsert and turn the phone back on and this is a soft reset and yoiu will lnot loose anything but that way your resetting you phone and the settings on it .. and if the phone continues to do that after you turning off daily and the soft reset i would contact warranty for replacement the phone might have a short in it .. if you with at&t the number to warranty is 1-800-801-1101
Posted on Nov 14, 2009
It's the phone..mine is doing the same thing. POS!!
Posted on Dec 20, 2009
Screen is showing blue background with sad face.
You have had a major problem, try the soft reboot, usually holding down both the vol down & on/off button same time for up to 15 secs till the phone beeps & resets, if that does not get it rebooted & back to normal, then you will have to download "Windows Phone Recovery Tool" to your computer plug you phone into the computer & allow it to reinstall the firmware to run the phone, this will be a full install but if you have backed up your phone & or had it on auto backed up to one drive, it will put your last back up of apps etc back to the phone, you will need to sort your start menu again though, good luck, if you have used the phones back up systems, then its never to much to get it back, you can get a new phone to the same as your old phone on initial start up by choosing the stored settings of the last phone you backed up. good luck
Jul 11, 2015 | Nokia Lumia 520 Windows Phone Black
I've been having problems with my phone for a while now. It's been freezing up, cutting off by itself, & other random stuff. Today, I sent a text & the phone shut off! I did the usual 'take th
Try to check if your phone memory still have enough space. common cause for freezing and shutting off is when your phone memory is almost full. try deleting some stuff.
May 25, 2017 | Samsung M8800 Pixon - Unlocked QuadBand...
Can a new thermostat fail? I put in a new thermostat, water pump is about 7 months old, radiator about 6, coolant is new and full, fans turn on, yet car would start to overheat regardless of idle or...
Easiest solution is air trapped in the cooling system. Make sure you have bled all the air out of it. If it has been properly bled then it might be your head gasket or a crack in the head itself.
Jan 23, 2011 | 1992 Honda Accord
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
Phone Restarting
Hi Friend,
The only solution u can do is as follows,
Initially switch off the mobile and then remove the battery and the sim card also
After 30 Sec u replace all the things in the mobile
Restart the mobile after 10 to 15 sec and then check it out,u wont get the problem again.
Regards,
Ayyasam
May 30, 2009 | Samsung C417 Cellular Phone
Fuel keeps cutting in and out
If it's an electrical problem, it's most likely your fuel relay. Try metering your fuel relay with a voltage meter. If you have voltage coming in, but not going out, then your relay is bad. If your relay is ok, chances are you either have a short in your wiring or your fuel pump is starting to give out on you. Your best bet's on the relay though. Hope this helps solve your problem. Have a great day!
Nov 23, 2008 | 1990 Mitsubishi Eclipse
Samsung Propel A767 Cell Phone Logo
234 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
