Question about Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000
What is the spark plug gap on powermate 6500 - Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000
  • 486 Answers
0.030"-0.035"
Posted on Nov 16, 2009
What should i do next to start my Powermate generator 5000.
Fuel evaporated or gone bad. Float in the carburettor stuck? When you try and start it, remove the spark plug and see it its wet. That will tell you if gas is getting through. Not a good idea removing any sensors.
If you are sure there is no spark, then you may need a new ignition coil.
Aug 15, 2015 | Electrical Supplies
What is a sparkplug gap for a powermate 43cc engine
Set spark plug gap to 0.024 - 0.028 in. (0.6 - 0.7mm).
Oct 11, 2014 | Powermate 10 in. 43 cc Gas 2-Cycle...
What size of spark plug for a colman 5500 generator?
any good lawnmower or car plug will work ,just gap @ 35
May 31, 2014 | Coleman Powermate Powermate 5000W...
Manual for powermate 54 series model#545020
what is the low pressure ( ) setting for a powermate 54 series
  • model 545020 is . because .i need a new fuel pump and dont have the manual for it thank you
Sep 30, 2012 | Coleman Powermate Powermate 5000W...
What is the Coleman Powermate 5000W Generator spark plug gap
Powermate 435001 w Subaru EX30 spark plug gap is between ..006 - .007 according to manual.
Sep 22, 2012 | Coleman Powermate Subaru 5000W Portable...
Coleman powermate clean machine 1500 won't turn over any ideas
A new spark plug should solve the problem. Had the same thing for the last 2 days would not start no matter what including starting fluid. Cross referance the plug with a Autolite Extreme Start plug $4.00 at Advanced Auto Parts and did not change the gap. 2nd pull it started and ran great!!
Jun 12, 2012 | Garden
What size of spark plug do i need for powermate pm0301010
Champion RN14YC, Gap is 0.28/0.31
This is per the owners manual for your specific machine. Hope this helps.
Aug 26, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
New spark plug, carb cleaned, new gas.....won't start......could it be the coil?
First check the surface between the rotor and the coil and make sure there is no rust. If there is take some fine emery cloth remove the rust from both the rotor and coil. Use a noncondutive cleaner to remove any metal particals. If you remove the coil you can use a standard business card to reset the gap.
After completing this process if it still does not start check the plug and make sure you have a spark in the plug gap. You can test it by removing the plug and reattach the plug wire then lay the plug on the head and try starting the engine. The spark should be a bright blue. If you do not have any spark recheck the plug gap. If the spark is a red color your coil is weak and needs to be replaced.
Nov 24, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000 Logo
235 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
