Question about Home
Eljer corner whirlpool is leaking around jets. What is the best way to stop it?
  • 2 more comments
  • Peggy Brunson Nov 16, 2009
    It is leaking around the jet body.
    The jet is cracked in the threads. It has to be replaced. Everything is glued. How do you replace piping?
  • Rod Kidman
    Rod Kidman May 11, 2010
    Leaking around the jet body or from where the PVC pipe goes into the jet body?
  • Rod Kidman
    is it leaking around the jet body or the piping going into the jet body?
  • 119 Answers
You need to remove jets check for cracking if so buy new jet if not cleanup and use a 100% clear silicone to re-install
Posted on Nov 15, 2009
  • Mike Linderman
    Mike Linderman Nov 23, 2009
    Sorry about late response but you should be able to use standard pvc parts on the flexible piping
Where can I get a replacement ring for around the on/off switch
rom plumber whole sale shops, pool or spa shops
take your s along as a sample or take a photo of where it goes and dimensions
May 07, 2016 | Eljer Laguna Six Jet Whirlpool
I need to know how to clean the jets in our eljer spa tub
Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link to the cleaning products I can find right now. There may be other out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Oct 04, 2013 | Eljer Home
What type of aromatherapy products can I add to my Eljer Stratus SILENTJET
any aromatherapy products can be used in jetted bathtubs.
US Parts Center
Apr 21, 2013 | Eljer Stratus SILENTJET WP 6x36
I have a Jacuzzi Cirrus, bought in 1996. It leaks slowly (I have to fill every 2-3 days. It drops about 8 inches and gets close to below skimmer. Do you know what could be leaking?
Each of the jets have rubber gaskets. The continual heat and cemicals starts to deterioate these and the tub leaks around the jets. This is not always noticeable do to the fact that the water is hot and tends to evaporate. But even a small leak multiplied by all the jets adds up. 1996 is a long time and the replacement of these gaskets are overdue. I hope this has helped it would be the first thing I would look at given the age. Hope this has helped good luck and have a great day. Jeff
Mar 29, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Eljer jetted tub on and off switch will not work
It may seem like a dumb answer but check the ground fault outlet or breaker. Then make sure there is enough water in the tub. It should be a few inches over the jets.
Mar 23, 2010 | Eljer Home
Back jet near front panels leaks, what part do i
You may not need to replace any parts. If it is leaking around the seal (which I have had happen on occassion), a high quality silicone adhesive should be applied. However, it is best to unscrew the jet at the connection so as to get good coverage. Just applying the adhesive around the connection without getting it between the unfinished portion of your tub, is just asking for future problems.
Nov 17, 2009 | Jacuzzi Cetra Whirlpool Bath LH WHITE...
We have a leak on the backside (wall) on our Fiore
if the tub is leaking from a jet, you have to get to it to remove it, put a bead of silicone around the wall fitting and reinstall it. no other way.
Nov 10, 2009 | Jacuzzi T601-959 Fiore Whirlpool Bath...
Jets not working
i have seen this in the past, a ground fault electrical outlet on the inside of a roman tub,if you have a 2 story house look for access panel on or by tub. otherwise you have to remove tile or other to access motor, you probably need a step too anyways
Mar 12, 2009 | Eljer San Antonio Acrylic Whirlpool -...
Jacuzzi Leaking
you need to pull the jet body out and then put some 100% RTV silicone around the jet body and the inside of the wall fitting. Once the silicone is in place re-assemble the jet. that will solve the leak unless there is a broken piece on the jet body or the lip of the wall fitting.
Dec 09, 2008 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Home Logo
102 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
