Question about InFocus LP70+ Multimedia Projector
InFocus LP70 keeps shutting off - InFocus LP70+ Multimedia Projector
I solved my issue with just simply upgrading the Frimware. Which can be downloaded from infocus website.
Posted on Dec 24, 2009
  • 2,237 Answers
If the fans go off imediately too, it's the power supply. if the fans stay on, it's either the lamop, ballast, or colorwheel. either way, you may need to send it in to an infocus service center. try av solutions in ny. they're really good. www.avsolutionsny.com
Posted on Dec 11, 2009
projdoc
  • 2237 Answers
SOURCE: Infocus LP70 dropped and now
try pulling the outer ring out a little while twisting it (you won't break it). then try the inner ring. if it wiggles, you need to take it apart- and that's not a pretty job.
Posted on Jun 05, 2009
projdoc
  • 2237 Answers
SOURCE: pile of ##@!#@ infocus lp70 green light wont come on. should i smash it??
if the fans aren't running, it's the power supply. if the amber is on and the button's won't turn it on, there is an obstruction under the button panel. if all turns on but the lamp and you don't hear a high=pitched whir, it's the colorwheel. if you do, it's the ballast.
Posted on Sep 03, 2009
  • 74 Answers
SOURCE: InFocus LP70
Have you tried another lamp? Sometimes thats your problem, but I've seen a several occasions that the a defective power supply causes this symptom. Do you see an image flicker before the projector shutsdown? I do have some spare parts for this projector.
I'm on Ebay - gtitubro if you want to contact me through there.
Posted on Sep 19, 2009
  • 167 Answers
SOURCE: InFocus LP70 color problem
No it's not the color wheel. If the color wheel stalls the lamp will shut off immediately which is a built in protection mechanism. On the LP70 and 70+ there is a multi pin connector inside located at the rear lower left of the projector. This connector connects the main board to the DLP engine electronics. This connector is horizontal and approx 2 1/4" wide and 1/4" thick and about 100 pins. I have seen this connector not seated completely and many various video artifacts occur (even the one you describe) If you or someone you know is electro-mechanically savvy it's not difficult to open the projector and make sure this connector is seated properly.
You will need a TORX T8 screw driver.
Cheers
Posted on Jan 16, 2010
  • 261 Answers
SOURCE: i cant get an image from the macbook pro onto the
hi
check your input with remote control(key-menu)
there is different input that you have to select the one you connected in (RGB- analog- digital)
Posted on Jul 29, 2010
Process to upgrade firmware for InFocus lp70 ... can some describe this for me please? I've got the firmware downloaded, but my PC does not see the projector .. Help!! I also can not find the USB drivers...
Go here: https://portal.infocus.com/support/Product%20Pages/downloads.aspx?mic=LP70%2b&on=downloadsthen down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
Apr 27, 2011 | InFocus LP70+ Multimedia Projector
Screen keep jumping
This is probably a voltage issue with the power supply especially if it is an LP70 type projector. If not it is still a power supply problem that will have to be fixed.
Oct 27, 2010 | InFocus Office Equipment & Supplies
I have a 6year old infocus LP70 projector. its footstopped gripping, so i opened the case and bodged a permanent pastic knob to keep at an APPRPRIATE LEVEL - BU i SEPARATED TWO WIRES ON THE LINK BETWEEN...
if you are talking about the ribbon connection on the rear of the main board, then yes I would scrap it unless you want to try and find a LP70 on E-bay to use for parts. You may or may not get a good board but if the price is under 50 bucks it may be worth the risk.
Oct 16, 2010 | InFocus LP70+ Multimedia Projector
Light does not come on, fan is working and green light at top keeps blinking off and on on a LP70 infocus projector
if you hear a high-pitched whir, the problem is either the ballast or the lamp. if you don't, it's the colorwheel. you could try to get the parts from an infocus service center or send it in to them for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 22, 2009 | InFocus LP70+ Multimedia Projector
LP70 Infocus Projector light will not start up
if you don't hear a high-pitched whir, the colorwheel needs to be replaced. if you do, it's either the lamp or ballast. if the lamp is new, replace the ballast. you can get the parts if you want to do it yourself, or you'll have to send it in. either way, try av solutions in ny. they are an infocus service center and they're really good. www.avsolutionsny.com
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70
Sep 17, 2009 | InFocus LP70+ Multimedia Projector
try resetting the settings to factory default through the menu. if there's still a problem, take the cover off. if you look from the back of the machine, inside on the bottom left, you'll see the main board attached by a large white plug. use something thin and non-metalic to push the bottom of the board towards the plug to tighten it. now do the same to the other side of the plug. this should solve it. if it doesn't, you need to replace the main board.
May 11, 2009 | InFocus LP70+ Multimedia Projector
Why does picture brightness change up and down on LP70.
Hi there
Sounds like the lamp is going , but it could be the Ballast as well ( lamp's powersupply ) Rather have a certified technician look at.
Mar 22, 2008 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
1,224 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
