Question about Dell Latitude D600 Notebook
Fry's copied my ST94811A drive to a WD 3200BEVE. I have a Dell D600. I get highly intermittent system failures and the system shuts down. Can a D600 handle a 320GB HD? I re-enstalled my old drive and so far no failures.
  • 3 Answers
I recently worked on a D610 to replace the hard drive with a new 320Gb WD and learned that the BIOS does not support drives larger than 137GB. However, Windows has no problem with it. If you create primary boot partition larger than 137 GB, Windows will not boot. So, the solution is to create a primary C: partition no larger than 137Gb and create a second logical partition (D:) with the remaining space.
Posted on Dec 19, 2009
  • 3,940 Answers
By virtue of the fact that the system boots to the 320 indicates the system can handle the drive, as it is pretty much an either or proposition. Either it works or it doesn't
More likely is that there is some data corruption that occurred during the data transfer. I know for a fact, that the virtual memory swap file can have issues after being cloned. So you may want to delete it by disabling Virtual Memory, rebooting and re-enabling it and rebooting again.
The BIOS flash recommended by MalKontent68 is a great idea too as it always is helpful with new hardware to have the most current BIOS.
Posted on Nov 16, 2009
  • 748 Answers
D600 is a rather old laptop. It may need a BIOS update - go to DELL support website and look for a BIOS update for your model (quickest search by providing the Service Tag number).
Posted on Nov 14, 2009
Dell d600 freezes intermittantly
sounds like the hard disk drive is slow to spin up. Sometimes older drives don't get all the way up to speed at boot, then with repeated restarts, the drive warms a bit and the spindle friction drops allowing full speed on the drive.
Try running HDD Diags the 1st boot of the day Fn +power button, see if you get any diag failure. Generally, a drive has to be within 3% of rated drive RPM (5400 or 7200) to function
Jan 11, 2010 | Dell Latitude D600 Notebook
Hp pavillion dv2210us harddrive failure
sounds like it may have died try it in an external mount (on a different computer)
Aug 13, 2009 | Dell Latitude D600 Notebook
Dell Latitude d600 series.The shut down after start-up
when your computer is freezes up then you download registry mechani it can improve your performance
Jun 28, 2009 | Dell Latitude D600 Notebook
Won't load Desktop
Is this running XP? Does the computer shut down or just go back to the welcome screen and ask for your password again?
If it returns to the welcome screen (and it is XP) get the following two files from another xp machine and copy them to the windows\system32 folder.
userinit.exe wsaupdater.exe
Restart the computer and log back in.
Hope this helps
Apr 28, 2009 | Dell Latitude D600: Pentium M 1.6GHz,...
Dell latitude D600 display blacks out, showing just a ghost image
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 21, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 will not boot
This problem can be solved by scanning the computer from viruses.
thanks..
Jan 31, 2009 | Dell Latitude D600 Notebook
Dell d600 lcd problems
The power inverter for the lcd backlight could be bad.
Mar 04, 2008 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
Kernel stack inpage error
i have recently experienced my computer is shutting down with a message kernel stack inpage error when i play a high graphics games or playing video files
is this fixable
Feb 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Latitude D600 Notebook Logo
169 people viewed this question
Alun Cox
