Question about Pentax Optio S4i Digital Camera
When I turn the camera on I get the message "memory card error". The only button on the camera which then works is the menu button but it just brings up the screen and then the same error message. Yes, I have replaced the memory card and the first memory card works in our other camera so it is not a problem with the card. My computer also fails to recognise the camera when I connect it via the usb port. Any bright ideas?
    Brigadier General:
  • 11,967 Answers
You need to format the card in the camera. Go into the menu and scroll to "format" and follow the on-screen instructions. This will erase and initialize the card . To download pictures, the most trouble-free way is to use a card reader and download to a folder you create on your desktop.
Posted on Nov 14, 2009
Card error
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
May 06, 2010 | Olympus E-1 Digital Camera
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
I just bought a new memory card but I keep getting "Internal Memory Full" message. How can I fix this problem.
Your camera is supported by: Memory card support : SD/MMC up to 2 Gigabyte. If you are using any other card your camera might give you an error message such as this one.
Try to format the memory card in my camera? NOTE this will delete all existing data on your card.
Do the following:
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
  4. Scroll up or down to the Format option, then press the OK button
Dec 18, 2009 | Kodak EasyShare C763 Digital Camera
New memory card doesn't work.
Did you format the camera before you inserted the new memory card?
Jun 14, 2017 | Nikon Coolpix 800 Digital Camera
Hi, I have a Canon Power Shot S2 IS 5.0 megapixels that was working fine until one day I changed the memory card from 512MB to a 1GB. Now every time I turn the camera on and try to take a picture, a...
Its possible that there may be an error on the camera try to reset the camera by
1. Turn the mode lever to the camera or play button
2. Press and hold the MENU button for more than 5 seconds.
3, The message "reset settings to default?" appears
4. Use teh arrow buttons to selelct ok. then press the SET button.
5. It should then reset the camera.
AFter doing that and the problem is still there. Format the memory card using the camera.
I hope this has answered your question sufficiently. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 06, 2008 | Canon Cameras
Memory card error
hey man I have the exact problem my one is exactly the same i need help for it
May 14, 2008 | Pentax Optio S4i Digital Camera
Format Error in Sony Cybershot
it could be a faulty memory card, but a more likely cause is that this stick isn't formatted yet. you can format it usually by bringing up the camera menu, then going to tools and format. you can also format it by using windows and a cardreader or your camera.
Mar 04, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Memory card
is it for a camera or a phone because if it is for a camera you have to format the memory card by the camera itself you cannot format the data or etc on the computer
Sep 26, 2007 | Samsung Digimax S630 Digital Camera
Error 10 message
The error 10 message is trying to tell you that the new memory card you have tried to put in is not compatable with your camera. AS you have already tried turning it off/on, replacing batteries etc, you can try taking all cards out, and attempt to get it to fuction correctly with original cmaera memory. After taking out all cards, and with a fully new set of batteries in, use your cameras menu to format the camera memory. Now try and take photos with just normal memory. Is it working? If it does, and error is gone, put in old memory card and reformat it. Does camera pick it up and recognise it. Can you now use it. The new card you tried to install may have been an incompatable brand. Check your manual for approved brands or your local dealer. The card could also be faulty.
Aug 08, 2007 | Nikon Coolpix 4600 Digital Camera
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Pentax Optio S4i Digital Camera Logo
90 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
