Question about RCA 36V430T 36" TV
RCA 36V430T will not turn on, Buzzing transformer 2127389A
My RCA 36V430T will not turn on. There is a buzzing sound coming from the 2127389A transformer. Can I repair it myself?
  • 20 more comments
  • dliptack Nov 14, 2009
    measured the horizontal output transistor, collector to emmitter resistance was infinite
    How do I measure voltage on flyback transformer?
    Note: buzzing is not coming from flyback transformer. It's coming from another large transformer. Would post pics, but not sure how. My pics are about 300kB
    mulitmeter set to R 20M, measure 17M from emitter (red probe) to collector (black probe). resistance is infinite when reversed. Also infinite for all other resistance ranges.
    multimeter set to 200V, measured 0V between collector and chassis.
    got pics below 150kb. can't figure out how to post them here, any suggestions?
  • dliptack Nov 15, 2009
    Links to pics:
    [IMGhttp://i918.photobucket.com/albums/ad23/...[/IMG]
  • dliptack Nov 16, 2009
    I believe I located the horizontal output transistor. Here's a picture:
    http://s918.photobucket.com/albums/ad23/...
    measured 0 Ohms between collector and emitter. Should I replace this transistor? Is it possible that the horizontal output transistor is shorted because something else is wrong, like a bad flyback?The device in my TV is a Toshiba S2055N. Any reccomendations on where to buy this part? I found it on www.audiolabga.com, but don't know if they are a trustworthy distributor.
    not sure if the picture link worked, here it is again:
  • dliptack Nov 17, 2009
    Removed horizontal output transistor. Flyback looks good with no burns or epoxy
    Measured horizontal output transistor out of circuit. resistance is nearly zero from collector to emitter
    picture of flyback showing red and black wires which go to CRT
    measured voltage from HOT collector to chassis (braided wire the wraps around tube) +130V when initially powered, and +132V when TV power button pressed. Here's a pic showing measurement point on HOT collector (c)
    Various CRT and yoke pictures
    Picture of back of CRT board. Flyback black wire is connected to BB003. Also black wire from CRT board to braided wire wrapped around tube is BB004 position "AA 3" on board, which is also the point where I connected to chassis ground for voltage measurements.
    I also noticed a possible cold solder joint on a capacitor (CL021) near HOT
  • dliptack Nov 18, 2009
    measured diode shown in last posting:
    Blue-Brown wires from last posting goto this board:
    Blue-Brown-Red-White wires behind HOT heatsink go to interconnect board then to yoke. Note Blue-Brown-Red-White at interconnect correspond to Yellow-Brown-Red-Blue at yoke:
    Just purchased HOT (S2205N) which arrives in 2-5 days from:
    http://www.electronix.com/catalog/produc...
    Wasn't able to resolder components near HOT and Flyback, will do tomorrow
  • dliptack Nov 19, 2009
    Solder looks good, resistance check ok on items 1,2,3. Couldn't find TO-3P package part, but found T0-220FP ST's IRF630FP at TL101
    Expanded view of board behind/near yoke teminal (exhibit A). Yoke terminal board moved for better view:
    Your last picture: resistance check on DL121, DL122 is 132.2 ohms
    www.electronix.com called and S2055N HOT is on back-order, my order was cancelled. Couldn't find the part on www.encompassparts.com. Searching for a new distributor. May try www.audiolabga.com
    Just ordered S2055N HOT from www.audiolabga.com, not sure how long it will take
  • dliptack Nov 21, 2009
    The S2055N HOT (qty. 2) just shipped. I should have the parts by 11/24.
  • dliptack Nov 23, 2009
    Touched up solder joints around chopper and HOT.
    Also measured 3.15A fuse FZP60 (OK) and RP068 4.7 Ohms (measured 0 Ohms). I'll try to find a 4.7 Ohm resistor to replace.
    I should receive two HOTs in two days. Should I solder the new HOT into the circuit and power up, or are there some tests I should run first?
  • dliptack Nov 24, 2009
    RL037 (measured 215 Ohms) and RL038 (measured 217 Ohms). Color code says 220 Ohms.
    RL010 (measured 0 Ohms) and RL012 (measured 0 Ohms). I think this is OK because I think my multimeter can't measure 0.22 Ohms and 0.100 Ohms accurately.
    Found a resistor to replace RP068 (4.7 Ohms). It's 4.64 Ohms. Let me know if this isn't OK, then I'll look for an exact match.
  • dliptack Nov 25, 2009
    Got the S2055N (qty 4) in the mail today. It's now soldered in place.
    Used my 4.64 Ohm +/- 1% resistor in place of 4.7 Ohm at RL068. Will power-up tomorrow when I have time to monitor.
    New S2055N installed, removed connection to yoke (exhibit A), connected TV to power. Measured 130V between S2055N collector and chassis. Heard hissing noise. Held for 2 minutes. S2055N did not get hot.
    Turned on TV (power button) and S2055N blew. 0.0V between collector and chassis. Removed part which is now shorted between collector and emitter.
    Installed a new S2055N. Any suggestions?
    I have 3 spare S2055N HOT's, including the good one in circuit.
  • dliptack Nov 28, 2009
    Made a few more measurements with new HOT. Also TV plugged into power but not turned on, connection to yoke removed (exhibit A), and black terminal on multi-meter connected to chassis ground (braided wire). Before DP080 voltage fluctuates between about 19V and 23V. After DP080, 131.9V. After DP061 19.7V. TL033 collector 10.75V.
    With yoke disconnected, new HOT, and TV plugged in but not turned on, I measure 0.0V at RL007, RL010, RL012, DL011, DL013, and DL040. As soon as I turn on TV the HOT pops (don't hear sound on speakers or see dot on screen). Installed a new HOT (only one left after this one). Here are some pics of CRT board, bad HOT's, RL007, possible flyback damage?, DL040 connection to CRT board [IMGhttp://i918.photobucket.com/albums/ad23/...[/IMG] [IMGhttp://i918.photobucket.com/albums/ad23/...[/IMG] [IMGhttp://i918.photobucket.com/albums/ad23/...[/IMG] [IMGhttp://i918.photobucket.com/albums/ad23/...[/IMG]
  • dliptack Nov 29, 2009
  • dliptack Nov 30, 2009
    Resoldered joints in steps a), b), c). Resistance between base and emitter of original S2055N is 41.5 Ohms. DL010, DL011, DL012, DL013 do not appear to be shorted. Soldered original S2055N base and emitter to board (bent collector out of way). Measured 0V (-0.007V) between base and chassis. I have a 100W incandescent light bulb. Where should I connect it? If there is a bad tripler diode do I need to replace the flyback? Is it part of the flyback assembly?
skippy101
  • 143 Answers
SOURCE: rca tv wont turn on after lightning storm
this is tipical you have some caps in the main ac power supply that are designed to take a spike of ac one is probably open or shorted if you are brave open set and see if you can see where smell is comming from.get back to me
Posted on Nov 02, 2007
  • 135 Answers
SOURCE: 36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
Posted on Jul 02, 2008
  • 159 Answers
SOURCE: when my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
Posted on May 02, 2009
SOURCE: my 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
my 36" rca green light blinks 3 times, no picture or sound
Posted on Jun 02, 2009
koolmind
  • 75 Answers
SOURCE: TV will not turn on
There is a problem with your power ic..U need to replace it...
Dont forget to rate
Posted on Sep 07, 2009
Lcd buzzing
sounds like a transformer having an issue either the power supply or inverter. You should be able to isolate which one by removing the rear cover then turning on the cover. ( Dont touch anything when its plugged in and playing just listen to see if you can tell where the sound is coming from.)
Feb 11, 2013 | RCA 42LA45RQ 42 in. LCD TV
There's a buzzing sound coming from our RCA Scenium tv, how do we fix it?
Are you using RCA type audio cables?, if so, make sure the connectors are tight and the cables are not frayed, it also helps routing those analog cables at least 8 inches away from any power cords or transformers. Buzzing usually is caused by loose ground connections or RF interference.
HDalacarte.com guy, audio/video/computer technician for over 30 years
May 26, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
The green power status light will come on, but the screen will remain black, There is a buzzing sound coming from the back, it sounds like it's coming from the smps transformer not the flyback transformer,...
The buzzing comes from the transformer of the power source - it's overstressed by a short. To find out which part is shorted you must check the voltages on the output lines from the source - the voltage on the one powering the faulty part will be way lower than normal. Follow that line and test every single component until you find it. But on your tv the first thing i would test is the horizontal deflection power transistor - the one that powers the flyback.
Nov 06, 2010 | RCA HD52W58 52" TV
RCA D52W19B makes high pitched buzz when on
Sounds like a coil is vibrating or a component is bad causing the transformer to whine. Could possibly just need soldering.
Jul 08, 2009 | Televison & Video
Rca 36" 36v430t
Without seeing the actual set, I can only suggest some of the common things that can cause this. Based upon your description, I would first look for a poor solder connection where the AC cable connects to the board. Look in that area for any charred spots. Let me know if there are any. The bussing usually is arcing of the AC power.
Dan
Oct 23, 2008 | RCA 36V430T 36" TV
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
Buzzing sound
Needs new,fresh IHVT ( flyback transformer) = I have part #
if you want it........T.
Nov 19, 2007 | RCA F32450 32" TV
RCA 36V430T 36" TV Logo
1,812 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
