Question about Samsung LN-S2651D 26 in. LCD Television
Recording why is it I have to keep my tv on to record. when I turn it off and set the timer on the video recorder nothing records!!!
  • 31 Answers
The only thing that comes to mind is that you might have your recorder hooked up to the video out of your TV. Most times the video out only works when the TV is actually on.
check how you have your cables routed and reply back if this isn't the issue.
Posted on Jan 09, 2008
6ya staff
SOURCE:
How to record
Be sure you have first set the clock correctly. After setting timer recorder time, channel, speed etc. hit enter to highlight the setting to be sure you have it. Press setup to put you back to tv screen. Then press t-Set button on remote. Unit will automatically shut off and there will be an amber symbol on the unit lcd along with the time. This indicated the unit is in the timer mode. It will automatically turn on and record the program at the set time.
Sep 26, 2012 | Sylvania DVR90VE DVD Recorder/VCR
Trying to do a timer recording to a Toshiba SD-V296KU DVD Video Player/Video Cassette Recorder. all seems to go with the recorder device but when I do the playback it is a blank screen. Is that because the...
I have a Toshiba DVD Video Player/video Cassette recorder - the problem is that when I set the VCR to record for an hour it will record for less than that hour and eject the tape. Help!
Mar 01, 2011 | Sansui HDLCD-4212 LCD TV
TV plays fine when dvd recorder is off. As soon as you turn on recorder the picture gets snowy. It doesn't matter whether it is on video 1 or on the channel setting. I have changed all the cables, still...
It seems that you are keeping the recorder close to the TV set resulting distortion in the picture due to power supply hum,check by keeping it away from set if no change than check the reason of hum received from power supply of recorder by replacing electrolytic capacitors for leakage or proper shielding of power supply in side the recorder.
Jan 22, 2011 | Panasonic DMR-ES40V DVD-Video Recorder
With 2 tvs you set to record on 1 and it records on 2 instead?records on the opposite tv
Hello, Matthew Gonzales with DISH Network here. The default setting in our receivers are to automatically record everything onto TV2. You can change the setting by pressing menu-8- 5 (preferences-record plus), then you can either disable the feature, or set it to record onto TV1. If the feature is disabled, the show will record at whichever TV the timer is set up on. If it is set to TV1, all timers will attempt to record on TV1 (unless TV1 already has a recording going on it then it goes to TV2). Hope this helps.
Matt
Jan 04, 2011 | DISH Network DVR-625 DTV Receiver /...
I have a vwm-400 Sanyo video cassette recorder. The clock on the recorder is set to the correct time! I programmed time recording for a set time to record a program on TV, but timed recording is not...
After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel.
Let me know if you have additional question.
Thanks.
Dec 18, 2010 | Sanyo Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
I cannot get the VCR/DVD to record from my tv. I have a satellite dish. The input from the dish receiver to the tv is HDMI1. The DVD receiver hooks into the AV1 inputs. I can set the timer, but nothing...
I have no direct experience but you should note no recording will take place unless the signal format is suitable/compatible. HDMI is a digital signal and your VCR/DVD will probably require an analogue signal.
A tv processes the digital into analogue but sockets at the back of tv sets tend to be input only. A minority of tv sets have two scart sockets, the second one usually providing an output sound and video of what is playing on the tv at the time.
I believe it is possible to buy a box that will convert digital to analogue or vice-versa.
Nov 16, 2017 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't use timer setting to record Foxtel on LG RH397D
Are you trying to use video plus?try manual setting and in the channel space put av1
Sep 21, 2009 | Televison & Video
Recording on my Dish 625 dvr
Okay, we can do this. Go to the menu on the satellite at either TV locations. and press 8 then 5. You are now at the Record Plus screen. Move the highlight to the record preferenceand toggle up or down to the desired record preference.After this ensure that you select enable on the activation side of the screen. You will then need to select done. Now you are in business! Thanks ffor using Fix Ya.
Mar 23, 2009 | DISH Network DVR-625 DTV Receiver /...
Cannot record VCR thru Cable Box
make sure that the cable runs first through the cable box then through the VCR then to the TV.
if you know how to set timers on your cable box (if you have that option), set those in addition to your VCR timer. If you don't have that feature or are not sure, you will, unfortunately, have to keep the cable box on a certain channel before you record.
hope this helps!!
Feb 10, 2009 | Panasonic Televison & Video
Samsung LN-S2651D 26 in. LCD Television Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
