Question about Hitachi 61SWX10B 61" Rear Projection Television
We have a Hitachi 42 inch TV and the color is not right and the screen has shadows
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
MOST OF these sets use two STK-392-110 CONVERGENCE CHIPS---IC'S.
Depending on ACTUAL model number I can tell you what is needed to repair this. Go into customer menu and if convergence looks skewed and will not adjust both chips and any bad resistors around them that are bad, need to be replaced.
Considering that parts cost for this repair is under 30 dollars---if you or someone you know can do it you can save the set and a lot of money.
Most shops get at least 300 for this type of repair. It should be fixable right in your home in about 1 hour--I know as I have done hundreds of these repairs.
Get me the Model number and if you have questions
I will assist you--I am here to help people.
If this has told you something you did not know, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 14, 2009
Hello, I have a Hitachi 42" RP, model #SP-43H. All of a sudden the color on the screen is distorted and is creating a double immage in Red and blue'ish green. Any advice as to what I need to repair this? ...
Common problems on DLP projection tvs.This problems is known as a convergence problems,it dead.The colors lines R,G,B mis alignment,colors shadows pictures and 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 02, 2010 | Hitachi Televison & Video
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
42 inch hitachi plasma
the more the tv remains on the picture gets out of focus mainly in the midle of screen. Sure sounds like tv needs some light engine repair or replacement.
Aug 11, 2009 | Hitachi 60V500 60" Rear Projection...
Blue shadow
No. I would suspect it being a Optical Block issue. I is not a pretty repair not to mention the cost factor. If you could get in touch with Hitachi Customer Service they could lead you to s service facility that could comfirm what I think.
Jun 22, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Fix the color on my tv
sir/maam kindly adjust its screen focus of your tv,,,,thankss and hopetohelp you,,,gud luck!!
Feb 27, 2008 | Philips 20PT6441 20" TV
HITACHI 42 INCH HD
Convergence Amp IC issue....originals are STK392-110..replace
W / upgrade Stk394-160E Hitachi part # CZ 01341 and check nearby resistors for overheating............................T.
Jan 07, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Blue shadow
colored shadows indicate to me a convergence or focus issue. convergence issues can occur on one part of screen. and most recognizable around letters. this might could be adjusted by a technician
Dec 07, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi Big Screen TV 46 inch Problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Sep 06, 2007 | Hitachi 46BX01B 46" Rear Projection...
Hitachi 61SWX10B 61" Rear Projection Television Logo
177 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
