Question about Nikon D80 Digital Camera with 18-135mm Lens
Sometimes I see a shadow when I use my Nikon d-80 flash. In hte lower section of the photo.
    Brigadier General:
  • 11,967 Answers
Are you using a long lens or a lens hood? Sometimes, this creates a shadow image.
Posted on Nov 14, 2009
Shadows on the bottom of close up photos
Use natural light or a ring flash. An onboard or mounted flash will alway produce a short distance shadow.
Dec 22, 2012 | Nikon D5000 Digital Camera
How to overlay picture in D40x camera
Overlaying pictures, like almost all photo manipulations, is better done on a computer using "real" software rather than on a camera. You get much more control on a computer. However, the D40 does have a wide repertoire of photo manipulation capabilities.
In order to overlay images, you must be shooting in RAW (or RAW+JPEG). Select Image Overlay from the Retouch menu. A preview dialog will be displayed with Image 1 highlighted. Press OK to get a photo selection dialog. Use left/right to highlight the first picture in the overlay. (You can press and hold the Zoom button to see the selected photo fullscreen.) Press OK to select the image. Optimize exposure for the image by pressing up/down. Press left/right to highlight Image 2. Select the second image the same way. Press left/right to highlight the Preview column. Overlay will show you the result, allowing you to go back and change things if you wish. Save will save the overlaid photo.
The shadow in the lower portion of your camera is probably caused by the lens hood. The solution is simple: remove the lens hood whenever you're using the built-in flash.
Mar 05, 2010 | Nikon D40x Digital Camera
When taking indoor photos, sometimes i get shadows on different placesof the photo
If you're getting shadows on the bottom center of indoor photos when take with a flash, it is most probably due to the length of the lens on the camera.
A long, telephoto / zoom lenses will create the largest amount of shadow, while shorter and wide angle lenses will be least likely cast shadows. You can reduce the amount of shadow in pictures by removing the lens hood that may be on the end of the lens. The lens hood is to primarily to shield the lens from direct (sun) light, and probably isn't needed for indoor flash photography. Also, rely less on the zoom function of the lens on the camera and physically moving closer to your subject instead. The flash will need to provide much less light output and result in more flashes per battery.
You could use a separate flash - held off the camera so that the lens is not obstructing the light of the on camera flash. Using a Nikon Speed Light, you can set the on camera flash to provide a low output, that would be used primarily to trigger a Nikon Speed Light held by someone or arranged on another surface etc. Youtube is a great source for real life, practical "How To" videos for many operations of the camera and accessories.
I hope this was helpful!
Oct 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
How can I match Metz 45 CL-1 with Nikon D-80
Try to keep the Flash setting on ISO-setting of 100 constant and adjust your aperture setting on the flash..Do not try to sync with the camera settings..it will normally work...for example.if your camera setting is as this: ISO-400, shutter speed is 125 and aperture is F8, then keep the flash setting as i mentioned above.this setting in an evening environment in a hotel or party event. this may help...
Aug 25, 2009 | Metz 45 CL-1 Flash
How can I match Metz CL-1 with Nikon D-80
you can buy a metz module to make them compatible.around 30 pounds price tag.
Aug 24, 2009 | Metz Mecablitz 60CT4 TTL Flash
Nikon coolpix 4800 - built-in flash may need to be replaced
I have the same camera and have had the lens cover get stuck and it will leave the dark shadow in the pictures like you describe. It doesn't always happen, but when it does I just gently push the lens cover all the way open with my finger.
Mar 05, 2009 | Nikon Coolpix 4800 Digital Camera
My Nikon N65 flash leaves a dark spot on all my photos
tlguthrie,
I love that camera. There are several possiblities, If you are using the pop up built-in flash with a telephoto lens or a lens hood you'll get a shadow in your photos ususally at the bottom of landscape oriented shots. If you are using a flash unit attached it may have something interfering with the strobe possibly or it is turned. We have the same camera and have had the shadow issue in the past. The pop up just won't work if something is wrong with the "bulb" the only other thing is that is isn't going all the way up, check that also.
randy32osgi
Jan 13, 2009 | Nikon N65 35mm SLR Camera
Does Nikon D70 come with an additonal bottom to plug in Bowen Flashfill
Are you using the built in speedlight on the camera with the lens hood fitted? If you are this will cast a shadow. Try removing the lens hood when using the pop up flash.
Nov 27, 2007 | Nikon Speedlight SB-600 TTL Flash
Shadow on image when using built-in Speedlight
The built-in Speedlight on many Nikon cameras is designed to be a convenient way to either light up a dark subject or to add fill light to a daytime scene. The built-in Speedlight cannot replace a full size, external speedlight which should be used when more power or coverage are needed. Because the built-in Speedlight is compact and close to the camera it cannot be used under all conditions. When using a lens that is physically very long, a subject that is very close, or a wide lens hood it is possible that a shadow may be cast upon the subject. Notice, in the sample below, the round shadow in the bottom center of the photo. When the lens is too long or the coverage is too wide with a close subject a shadow of the lens itself is cast. In figure "A" below the lens is casting a shadow. Switching (or zooming) to a shorter lens (figure "B") prevents the shadow and allows even illumination. If your lens, subject, or lens hood choice create a shadow, an external flash (either on the camera's hot-shoe or connected to the camera by a wire or wirelessly) should be used to fully light the subject.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D80 Digital Camera with 18-135mm Lens Logo
93 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
