Question about Efficient Networks SpeedStream 5100 Modem
The red light light goes off & on. The internet light will not come on??
  • 131 Answers
Bad firware is common, over a year old? if not use wty. if so may need to try a new one. as for the internet if using dhcp username & password must be perfect. also domains need the @ xxx.com after username.
Posted on Nov 14, 2009
Where do the two wires go from the rectifier on a 13hp briggs and straton single cylinder engine
From the engine model given you have a dual circuit alternator.
The red wire with the diode is connect to either to the amp meter if your mower setup has one or directly to battery side (large conductor) of the starter solenoid. It supplies a 3 amp unregulated DC charging current. The diode converts the Ac on that line in a pulsating DC voltage/current and it also normally prevents the discharge of your battery when the engine is not running.
The black wire is the AC output for your lights and is normally connect directly to the lighting circuit.
Nov 26, 2014 | Garden
I just bought a Deluxe VM .... when I plug it in, the red delay light is on....and everything has delay on it. When I press the little white button on the amp in or out, the red light on the amp still...
i guess the switch is broken - if you are not experienced fixing those problems better bring it to a shop and tell them about the problem - i guess they will be able to fix it easily
Feb 25, 2011 | Fender Deluxe VM Tube Amplifier
Cooper Industries Cooper Wiring 274W Switch and Outlet I need help installing this switch/outlet combo...I have 3 wires...a black, a red, & a copper. I hooked the copper to the green terminal, the...
Switch-plug combo:
bare ground goes to green screw
dark screw goes to hot from breaker
silver screw to neutral
brass screw goes to load (light)
Add a comment any time
You are replacing single pole light switch?
Single pole switch has 3 wires: black and red and bare copper
New device has 4 different colored screws: green, dark, brass, silver
Bare copper goes to green screw.
Black wire goes to dark screw
Red wire to brass screw
Nothing on silver screw for a moment. Test circuit and make sure light turns on-off.
If lights works, then good so far.
Now let look at silver screw. Neutral wire has to connect to silver screw.
In back of your electrical box are white wires twisted together and covered with wire nut.
These are neutral wires.
You must connect another short piece of insulated wire to these neutral wires and run that wire to silver screw.
The neutral wire will complete circuit to receptacle.
If you do not have neutral wire, then receptacle will not work in that box without additional wiring.
Hook up neutral wire to silver screw.
Now turn on power and click switch again.
If circuit breaker trips, then reverse your red and black wires.
Otherwise this should be correct wiring.
Dec 08, 2010 | Cooper Industries Cooper Wiring 274W...
I have a Fishman pre-amp mod MKAB Acoustic Base Optimized in a Michael Kelly Dragonfly 5FL TBK.. as soon as the plug is pushed in the jack, the battery lite on the amp flashes for an instant , then goes...
Most acoustic/electric pre-amp's red light comes on when the battery is low & ready to die. The red light flashes when you put the jack in because the battery light takes a fraction of a second to proccess. If the red light flashes off & on when you push on the pre-amp, it is probably because you are causing the battery connector to short or disconnect giving the pre-amp low voltage so the red light comnes on.
Nov 06, 2010 | Fishman Audio Players & Recorders
2701HGV-E Power Broadband & Internet led in
Check for the user name and the password for the connectivity. Internet light red only means either the user name or the password is incorrect. Try entering the password and try again it should help.
Jun 21, 2010 | 2wire (1000-000057-000) Modem
My sony xplod 1000w xm-1652z doesnt work anymore
First off, according to the manual, the protect light should be green. That's normal operation. If it is red, that's a problem.
If it does go red, disconnect all of the wiring to the amp except the +12V and ground. Short the remote connection to the +12V to force the amp on. If the protect light still lights red, the issue is inside the amp and will need repair. If the issue goes away, try reconnecting one wire at a time until the protect light goes red again.
Mar 23, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Overhaul light (red) stays on!
This is not a ovehaul light. It is called the protect indicator. It kicks in when the amp detects a fault on it's output. Disconnect the speaker / sub. Power up the amp and see if the light goes out. If it does you Sub is toast and needs to be replaced. If it stays on then the amp is done.
Jun 22, 2007 | Lightning Audio LA1.300.2 Car Audio...
Efficient Networks SpeedStream 5100 Modem Logo
218 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
