Question about Sony Cyber-shot DSC-W55 Digital Camera
What does it mean when your camera lens is not working and the screens say, turn off the power and turn it on again ? What happen if the camera lens is moving but ther screens is not opening or showing anything ?
  • 797 Answers
I may not have enough information for this... how ever, let us try. And I am not sure which one you are talking about, maybe both at times?
Does the camera play back files correctly and can be seen on the LCD?
If the first, then some problem exists with the lens. This camera then needs repair.
If no screen on the LCD, then repair is recommended.
In both cases, it seems the camera is in need of repair.
Because this camera is a few years old, I recommend to sell it for parts and as is on a site such as Ebay.
Posted on Nov 14, 2009
  • 846 Answers
If the lens doesn't extend and you hear a buzzing sound like a stuck gear or motor then your lens assembly is broken. There is a camera repair guide that shows you how to open a Digitial Camera and replace the part. The part is on Ebay. There is also a camera repair service that can do it for you.
Posted on Nov 25, 2009
When i turn on my camera the lens gets stuck coming out
Normal batteries it's not working for me!
After i replace standard alkalines with rechargeable NiMH batteries Sony and Varta 2700 Ni-MH it's was working!
Jul 16, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
My camera's screen suddenly went black after taking a photo. I thought the battery's low when that happened but the lense won't shut or come back. the On/off was just blicking. I tried turning it on again...
The black screen problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to Nikon service center. If your camera is under warranty period its well and good they will replace the lens sensor for free of cost.
Thank you
Jun 26, 2010 | Nikon COOLPIX L18 Digital Camera
When turning camera on lense opens then closes several times then the screene says to turn the power off and on again. Is there a fix for this?
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come out & go back. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Thanks.
Apr 02, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
When I turn my Sony Cybershot 7.2 mega pixel camera on, the lens keeps going in and out and the message "Turn the Power on and off again" shows up on the LCD screen. When I turn the power off and on again,...
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks,
KenSolutions
FixYa
Dec 06, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Nikon D70 will not power on after the lens was changed~
EDAWinc,
Is this a new or different style lens? You may not have it all the way on and aligned - try removing it again. Just remember to always turn off the camera before removing the lens or the SD card. Malfunctions are sure to follow if that happens. Try resetting the camera by holding down the two buttons on the top with the green dots for longer than 2 seconds (that works with the D80) The camera will not come on if the lens is not "on".
randy320sgi
Sep 29, 2008 | Nikon D70s Digital Camera
Turn the power on and off again
I fixed this issue with my Sony Cybershot by gently (carefully) hitting the camera 3 times against a carpeted bench with the lens retracted and the camera turned off. It seems the lens gears were stuck. Now the camera works fine again.
Apr 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Digital Camera Fault
ACCESS error could happen when lens gets stuck but if it happens when lens moves back and forth without problem it usually means that where the lens assembly plugs into main system board connection is loose. These connections are held in place by a very small thin fragile plastic clip and a few drops could be enough to snap it but not do any other noticeable damage to camera. Camera would need to be opened to see if clip is broken or maybe cable just needs to me reinserted. Either way only open camera if no longer under warranty and you are somewhat handy
Mar 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Canon Power Shot Pro1 will not turn on
A new camera will fix problem perfectly. LOL Did you drop it? Seem like there might be a short or something similar. Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
Sep 09, 2006 | Canon PowerShot Pro1 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
234 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
