I have a kenmore refidgerator with loose door handle
Hi, I have a 2005 Kenmore Cold Spot refidgerator, model# 106.5659400, type 26SSA. The door handle is loose and I can not figure out how to get into it to tighten it.
Thanks, John
  • 460 Answers
Usually there door tightening screws at the top edge and bottom of most frig doors there will be plastic caps covering the screws..
Posted on Nov 14, 2009
How do you reverse the door on a kenmore cold spot 106?
Take door off, reverse the handle and hinges to other side of door and reinstall.
Mar 04, 2016 | Kenmore Refrigerators
How to tighten loose set screws on freezer door handle on ken more fridge with bottom mount freezer, model no. 269-76353019
I think that the handle is attached either to the door edge or the face. In either case the screws are usually hidden behind a small trim panel. This needs to be removed to expose the screws. I don't know what type of screws have been used. They're usually cross heads but occasionally they require an allen key to remove them.
Jul 19, 2015 | Kenmore Refrigerators
We have the Kenmore model #795.78309.800 and the freezer drawer track keeps freezing up and make it almost impossible to open the freezer. This just started the other day.
the most common problem is a bad sealing door ,when the door is closed it is not supposed to let warm air in and cold air out ,but if the seal is faulty then the opposite happens and this causes the build up of ice,take a good look at the door seal a good way of finding out if this is the problem is to run your fingers around the seal when the door is closed for a while if faulty you will find a warm spot where the cold and warm mix causing a warm spot.adrian,,,,,,,,,,
Aug 13, 2010 | Kenmore 22.4 cu. ft. Bottom Freezer...
Freezer ok refrigerator not cold we changed the overload relay model no. 59673503201 kenmore elite
feel door seal after door has been kept closed for a quite a time.If it feels warm at any one spot door seal needs replaced.adrian;;;;
Nov 10, 2009 | Kenmore Freezers
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I have a Kenmore Cold Spot Model 70192000. Having
HI, I can help you with this. It sounds like the defrost drain is plugged. If you will get me the model# from inside the fresh food section of the refrigerator, I can look up this model and instruct you on how to repair this.
Thanks
Vic
Jun 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Lost freezer key
Hi, here is the replacement key for your model, you can purchase it for $ 2.65:
KEY (Freezer Door Key)
Mar 23, 2009 | Kenmore Freezers
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore cold spot refrigerator freezer
wow you have power to the unit what about the temp control ? is it turned up?? if so is it closed(calling for cooling?) that is the place to start you can jumper it after yo unplug it to see if you dont have a meter
Jan 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Electric Range - Door handle
I had the same problem with my stove. I tried to replace, glue the srews and other things, but nothing really worked well. It's a shame that Kennmore has such a design flaw in their stoves, but did nothing to help their customers.
Here is the solution that worked for me:
Fix the thread with helicoils (these are inserts that create a new threat in the handle). You can find the instructions how to use the helicoils on Youtube.
I replaced the crews with new screws that fit to the helicoil threat and now the handle is safely secured.
Regards
Michael
Jan 03, 2008 | Kenmore 96213 Electric Kitchen Range
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
