Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
Volume not working
Picture is fine, both remotes work but no volume no matter how high I turn it up. Menu says speakers are on and I checked each connection.
  • 152 Answers
If you are connecting the tv through RCA cables, then you are not plug in right the red and white cables that are standard for audio... like the yellow cable that its a standard for video signal..
check if that seems to be the problem..
Posted on Jan 08, 2008
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
Toshiba 36a43 i have picture but no sound. Volume control works but again still no sound.
Things to check:
In menu are speakers (audio area) switched on or off?
If you put sound all the way up and listen right at speaker what if anything do you hear?
If using a cable or sat box is sound turned down on it?
Is sound muted on set or the box (if used)
Do you have sound with a DVD etc hooked via the rear jacks?
A few sets have a slide switch on the rear= internal or external speakers--is it set to internal?
failing all of the above you have a audio circuit problem
Mar 26, 2012 | Toshiba 36A43 36" TV
My tv turns on an off, and the picture and sound works fine. The problem I am having, is that no matter what button you push on the remote, or the tv itself, it just brings up the input. You could hit...
Tries websites like, to buy a refurbish manual functions controls board that have like buttons POWER,Channels + -,Volume + -,MENU.This manual functions controls board it is shorted.
May 21, 2011 | Element Electronics ELCHW261 26 in. TV
My speaker volume is very low no matter what i play. All volume controls are up as high as they will go
Have you checked your system audio volume?
If you are using Windows XP go to Start menu -> Accessories -> Entertainment -> Volume Control
Make sure that the volume is set to the highest value.
Mar 04, 2011 | Polk Audio AMR50 Computer Speakers
I have a Quasar TV that has worked perfectly fine until the other day. Picture is fine, but no sound. The speaker volume is on.
Check all your channels. If you are getting sound on some channels but not others it is a good possibility that your SAP setting is turned on. Simply go into your audio menu and disable the SAP. Not sure about your model tv but some Tv sets had a switch on the back to disable the speakers and some have a setting in the menu to disable the speakers. If you have a digital cable box hooked to the tv it is possible the cable box volume is turned all the way down which will override your tv volume. Check these options and hopefully one of them works for you.
Jul 10, 2010 | Quasar SP-3235 32" TV
Tv sound wont work
Make sure that all scarts and sockets are plugged in tightly. Try different inputs, try connecting a DVD player or another piece of equipment to the sockets in turn. Also, if you`ve got a sky box, remove the scart plugs one at a time and reconnect it immediately so that you know where you took it from. Check if there`s a switch on the back for external speakers, Make sure it`s switched to internal. Some of the TV`s have the switch for internal and external speakers in the menu`s. Make sure that any switches whether mechanical or electronic are switched to internal. Ian
Jul 24, 2009 | Philips Televison & Video
Volume at high but sound low
Ok try turning the sound control up either on your speakers if it has volume control or go to options on the game menu and then go to sound option and turn it up, also if you are talking about that on your speaker volume control is up but sound is low try also bottom right of the screen if using windows find the little picture of a speaker, place mouse arrow over it right click and increase volume on system. Hope this helps you.
Sep 08, 2008 | Computers & Internet
No volume
Have you checked to make sure that your speakers are turned on? Most rear projection televisions have both a physical switch and an interal menu option to turn on and off the built in speakers. The physical switch usually is located in the back near the inputs and outputs. It could have accidentally switched off. Under the menu options it may have been accidentally turned off as well.
Sep 01, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Vizio speakers make a buzzing noise
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
Mar 08, 2008 | Vizio L37 Television
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
