Question about Linksys WRT160N Wireless Router
I can not connect my play station 3 to my linksys wireless g broad band router.
  • 131 Answers
All network setting correct on playstation? try there support site www.linsys.com it is actually very good. Try wired or new wire if using wireless. this is a very finicky router. I have had to spend many hours playing around and reading. mine was the mtu setting was to low. set to 1492 and I changed to like....1600.
hope I helped, let me know
Posted on Nov 14, 2009
My connection is bad when playing online on my playstation 3 when my mom is using her laptop and i thought dual band was supposed to put me on a different band for a smooth sailing connection!?
maybe for any online multplayer games I recommend just using an Ethernet cable if possible, let your mom have wireless all to herself on the laptop, any wireless for online multiplayer games just sucks
Jan 21, 2011 | Linksys WRT610N IEEE 802.3/3u IEEE...
Hii i have a linksys2.4G broad band router .it
On the back of the router there is a recessed reset button. You need something small like a paper clip to push it. Push and hold it for 15 seconds. This will completely reset the router to factory settings.<br /><br />You will need to use the default password that came with the router to get in. It should be Admin, but refer to the manual for that. You can find it on the linsys website if you don't have yours.<br /><br />When you plug your computer directly into it, you should go to 192.168.10.1 to access the router.<br /><br />You will have to set up all your settings again.<br /><br />If by chance the default network ID was changed, and the reset did not effect it.<br /><br />Basically the fist 3 sets of numbers in the IP address is called the network ID.<br /><br />Plug your computer into the router and start it. When its up got to run, and type CMD and hit enter<br /><br />Then once the command prompt comes up type ipconfig and hit enter<br /><br />Find the line that says IP address. Take the first 3 sets of numbers from your IP address and type them into a browser, and make the last number 1 and it will access the router.<br /><br />
Aug 25, 2010 | Linksys Wireless-G Broadband Router
How can i connect the router? i got a intellinet 192.168.1.1 there is one wan and 4 ports are there.i have dialog broad band connection.how can i connect it?or iwant to install any software?
This is very easy to do and you should have no problems doing this. The first step to installing it connecting your router to your broad band router through the wan port. All you do it take your Ethernet cable that went from your broad band router to your computer and attach it to your new routers WAN port. next wile your new router is turned off, turn off your broad band router and then turn it back on wile it is booting up turn on your new router this is not always necessary but it will make sure that they sink together properly. And that's it your done just hook up all of your other computers to the remaining ports and they should work with out a problem.
PS. this is just the basics of setting up your router if it has wireless you may want to think about implementing some security measures such as encryption.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Intellinet Active Networking Intellinet...
My xbox360 scans and finds router but it will not connect. what is the problem?
Before connecting the X-box or play station or nintendo WII to the network, Make sure that you have all the wireless settings of the router.
if you don't know the wireless settings , then you will need to open the router set up to find the wireless settings.
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365.
Also you will need to open the ports on the router.
For WII port numbers are ==> 28910, 29900, 29901, 29920, 80, 443.
For XBOX port numbers are ==> 53, 80-88, 3074
For Play station port numbers are ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Click Here for more info
Dec 26, 2009 | Linksys WRT120N Router
I got the linksys router problem which no problem at all when i connected to sg broad band . currently use it to connect to malaysia streamys broad band and problem occured. when i connect the router to...
For that you enter in linksys configuration page with 192.68.1.1
then enable dhcp .
Aso set WAN settings as your internet service provider settings.
For that you have to set DNS server and other settings as your malaysia streamys broad band settings.
Let me know if you need further assistance.
Thanks.
Oct 28, 2009 | Linksys Wireless-G Broadband Router
Up grading my system in a up stairs & down stairs house
Only use one router. At the point of entry of the internet service provider(dsl or cable) connect your wireless router.(prefer middle of house) If you need a repeater for your signal do so but I don't think you will need one with N technology.
Sep 01, 2009 | Linksys WRT160N Wireless Router
The wireless cannot acquire a network address
is your router broad band and do you have install the cd that comes with if so unplug the modem and the router out of the outlet restart pc and plug the router andthe modem back in the outlet see if it works
Aug 05, 2009 | Linksys Wireless-G WRT54G Router
Linksys router model WRT54GX2 SRX200 drops wireless connection on the laptop and the ethernet connection on the desktop. Connection drops for seconds then reconnects in seconds. By-passing the router and...
read on the router if its broad band , if is not , you will not be able to use it , so my advice to you is get aother linksys router with broad band on it .wish you all the best
Aug 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys wirless G 2.4 broad band router download driver
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Feb 10, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT160N Wireless Router  Logo
139 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
