Question about Eureka 12 Amp Capture Vacuum Upright Vacuum
Eureka capture model 8803 type AVV...runs for 10 minutes then stops. will not re-start for a long time.
  • 36 Answers
This could be a few issues. First it could be the thremel swith located inside, or it could be the carbon brushes also located inside. If you are a do it yourselfer you can purchess the carbon brushes from any vacuum repair shop. The thermal switch should be tested before replacing "thus- you shoud have a local repair shop look at" I would find one that offers free estimates so they can diog. the problem. then buy the part and start the fun part. Saving big $$$$$$
Posted on Nov 14, 2009
The eureka model # 4703D does not **** although the motor is running
The vacuum cleaner probably is clogged. Look especially in the opening behind the roller and follow the path to the bag/container. If you have a pet that sheds, you can clog a vacuum quickly
Dec 29, 2012 | Eureka Capture Upright Vacuum Vacuum
We have the Eureka Capture and it seems the vacumm got hot and stopped, now it won't run. Is there a reset button?
If you go to this URL:
http://www.ereplacementparts.com/eureka-8853avz-upright-vacuum-parts-c-108750_108773_109342.html
you will see that item #25 is listed as a circuit protector. You can locate it on the exploded view drawing as to where it is on the unit. This is what you want to find and see if you can reset it.
If you find my solution to be helpful, I would appreciate a Thumbs Up.
Paul
Oct 07, 2010 | Eureka Capture Upright Vacuum Vacuum
I have a Eureka Capture and it works fine for 5 minutes then I smell some burning. Is this the belt?
It could be, open up the cover (there are two screws on the top) and then check the belt, and check the brush to see if anything is rubbing on the belt. If the belt seems fine then your problem is somewhere else.
Dec 21, 2009 | Eureka Capture Upright Vacuum Vacuum
How do you change a motor for a eureka model 8851
All of these vacuums capture the motor assembly between two plastic case halves, or are held in place by a band. Take out the phillips screws (sometimes the screws are under decorative plugs to hide them) and carefully pull one half off. You'll have a lot of taking apart to do, but if you actually got a replacement motor, it will be worth it.
Nov 25, 2009 | Eureka Capture Upright Vacuum Vacuum
Not sucing
The reason it is not picking up is probably because the belt is stretched, worn or broken and is not turning the brush the way it should and therefore not picking anything up. You should change the belt on your model at least once a year. Here is a link to the belt you need and a link to the owners manual which has belt changing instructions:
Eureka Capture Replacement Belts
Eureka Capture Owner's Guide
Nov 08, 2009 | Eureka Capture Upright Vacuum Vacuum
I'm using (or WAS using) a Eureka ''the boss'' model 8803. The belt broke, no biggie, so I replaced it with a Eureka model U belt, the problem is when I put the new belt on and turn on the vaccuum, the...
First, make sure you have the right belt, second, i am thinking that you are not lineing the roller up right, it will only fit one way. look at the ends of the roller and the grooves where it slides in, you should be able to see clearly how it goes.
Jul 26, 2009 | Vacuums
Wont turn on
usuasl the bushes have wore out on the motor .they need replaceing
May 24, 2009 | Eureka Capture Upright Vacuum Vacuum
Eureka 12 Amp Capture Vacuum Upright Vacuum Logo
367 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
