Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Jenn Aire double wall oven
I have a double wall oven. I keep getting the F2 error code for the top one. The lower one is working. I understading it could be the temperature proble. I tried taking it out but the terminal is behind the metal housing. Can you help me with my problem?
  • Andy BG Jan 08, 2008
    I tried that but it appears that the terminal is behind the wall of the housing.
  • 283 Answers
Get a long thin flat blade screwdriver. Gently pull the probe with one hand and press on the back side of the probe connector with the screwdriver until you feel no slack in the wires. Don't pull too hard! Rotate the blade of the screwdriver until the connector lines up with the opening and puill it through. Works for installing the new one too.
Posted on Jan 08, 2008
    Sometimes the connector is too big to go through. Unfortunately in that case you have to pull the oven to get to the back.
Oven shuts off with Error Code 4d21
This problem points to the controller card not functioning properly. It will need to be replaced. Here is a link so you can get the owner's manual:
Check it out, it may help you figure it out.
Mar 19, 2014 | Jade RJDO3003A Stainless Steel Double Oven
Had error code 9d22, on my jennair double wall oven, took out the lock module on the lower oven, fixed it and put it back. I believe it should work but the original error code is stopping it. How do I...
9d22 means that the oven door is still locked. Obviously you didn't repair the lock module since the control board thinks it is still locked!
Feb 02, 2011 | Jenn-Air Ovens
F4 error message
HI. This is a failed oven temperature sensor error code. Simply replace the temp sensor, asap. This will clear the code. The temp sensors are generally located inside the oven, mounted on the back wall, in the top left or right corner.
It will look like a 4 inch slim probe.
F4 failed temp sensor.
Dec 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
F2 code
F-2 error for jenn-air means the oven is to hot, it could be the oven temperature sensor is faulty, or the relay board.
Mar 29, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Top oven has an error code (f2) It happen after a cleaning
F2 - Oven Temperature Too Hot - Depending upon model, replace relay (if present) or oven temperature sensor. Make sure to check sensor harness.
Dec 09, 2008 | Jenn-Air JJW8630C Expressions Collection...
F2 code on Jenn air double oven
One website said its a relay board problem. Years ago I replaced the entire electronic board and did it myself and I am not overly good at such stuff, so it can be done if you find the correct part. I am having that problem and am searching for a relay board or whatever it is.
Dec 07, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn Air JMW8530CAB time/temperature light don't work
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
Nov 18, 2008 | Jenn-Air JMW8530C Electric Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
214 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
