Question about Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung SyncMaster 913N screen not working
I unplugged my computer while cleaning my flat a few hours back and since turning it back on have not been able to get my Samsung SyncMaster 913N screen to work. The Green LED flashes but the screen stays black. When I unplug the VGA cabe the screen says no signal. When I press the furtherest button to the left on the screen panel it says 'test good'. The screen was working just fine before I turned the computer off. Could it have overheated or something. Help please!!
Andy
  • 11,361 Answers
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Worst case will be the lamps.
Posted on Nov 14, 2009
  • Samsung Master
  • 1,684 Answers
Check for a bent pin in the vga cable. If a pin gets bent then the monitor gets part of the signal from the computer but without the sync signal it can't display a picture. If you find a bent pin just use a pair of needle node pliers to straighten it. If you can't straighten the pin you will need to purchase a new signal cable.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
I have a blank screen. Only when I press menu do ...
Me too... If I put it on 640x480 it also complaines that it want 1280x1040@60hz but there is newer a picture eaven if I give it that resolution...
May 20, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Syncmaster 913v not optimum mode
I just resolved this problem for my SyncMaster 913N.
It seems to be a known issue, however it can take quite some time for the problem to occur. In my case about 3,5 years, so well out of warranty.
Short term solution: unplug your monitor from power. The switch on the front is not good enough. Pull the plug and leave it for an hour or so (all night if you can). Good chance the monitor will work next time you power it up.
The problem will is likely to come back..
Permant fix requires some basic soldering as per this video:
I just managed it and it has been ages since I soldered a resistor so you may very well be able to do it. I spent $25 on tool and part and saved me from buying a new monitor.
Mar 20, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
My screen (not my monitor) just turned 90 degrees! how do I get it to turn back?
Try clicking ctrl>alt> and a combination of any of arrow keys (left or right or up or down) simultaneously, until your display comes back to place. Hope this corrects your problem.
Oct 22, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
Sasung 913n monitor
Same here. The unplug/inplug of the monitor seems to be the workaround. For now, I boot up Windows with the 913 unplugged and connect it after a couple of minutes when Windows has booted up. As mentioned before, this bug only happened to me after shifting to a PCIe card, Nvidia 6600 LE driver.
Dec 29, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Samsung 913n
can anyone tell me were i can download drivers for samsung 913n monitor please thanx carlos
Dec 17, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Turn Screen on and it displays white
I have a Samsung Syncmaster 175v Mfg Oct '03 displaying the __ White Screen . I removed the screws on the back , removed base stand, separated case with flat screwdriver starting at bottom, unplugged the small wire to the panel menu buttons , removed metal cover from back of LCD. Now you can see the powerboard \ inverterboard combo and the attached video signalboard. Follow the 30 wire plug to the LCD screen, the 30 wire plug goes under a metal panel , remove the 3 small screws securing the panel and you will see the hidden LCD screenboard. Very close to where the 30 wire plug attaches to this screenboard on the Rightside you will see with a magnifying glass a SurfaceMounted Fuse named F1 with a value? of "K". On my LCD the fuse tested with a volt-ohmmeter to be Open or Blown. The right thing to do would be to replace the fuse however I acquired my LCD from a trashcan / dumpster so I stretched a drop of solder connecting both sides of the fuse. Now I do not have the protection from power failures and surges that the fuse could offer but upon reassembly my screen works like new again .
PS : i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Aug 30, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Problem LCD screen stays white bright after switch button is OFF ??
Some capacitors need to be replaced,which would have burnt out due to power fluctuations
May 12, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
590 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
