Question about OfficeMax 0M96431 Shredder
Jammed with gummed stickers - OfficeMax 0M96431 Shredder
  • 748 Answers
Always put stickers in the shredder between two layers of 3-4 plain paper sheets. That's for future.
Now I would suggest getting some "Label Off", "Label Killer" or similar spray product, that will dissolve the glue, spraying the cutters and stuck labels with it several times, trying to remove them with tweezers or thin long-nose pliers. Be gentle, try not to blunt the cutters' edges.
When you get rid of the labels, spray more of the stuff on the cutters and clean them with a brush, to remove glue residue between them. Do it several times, rotating the cutters to remove the glue all around.
Then lubricate the cutters as per manufacturer's recommendations.
Posted on Nov 14, 2009
Colour Xerox Machine problem
its a problem with the fuser unit ,its overheating .two ways to solve it first check if the sticker paper is supported by your printer ,2nd you may need to replace the fuser unit
Oct 02, 2014 | Xerox DocuColor 242-252-260 PS
Bravia kdl52ex700 volume control doesn't work
Look for any jammed buttons on remote, any obstruction like a sticker or gum on the sensor on the TV. If you have such obstructions, the TV will respond only partially.
Aug 15, 2012 | Sony Televison & Video
My HP 2600n printer always jams if there is more than one sheet in the paper tray. If there is only one sheet in the tray, it never jams but if there is more than one sheet, the first prints and while its...
Hello ,
The pad of solinoied become teared & only gum left on solenoied by which on the paper picking proces it fix on the base,by which the picking rooler continious mooves & pick another paper & become jam.so clean that path & remove the gum & paste the tape .your problem will be resolved 100%.
jm
Sep 07, 2011 | HP Color LaserJet 2600n Printer
Is aregular sticker good as a screen protector?
yes as long as it does not gum up the screen. Anything to keep from scratching the screen would be better than nothing.
May 25, 2010 | SanDisk Sansa e250 MP3 Player
Ther was a sticker on the cd, cd came out sticker stayed in now there is an error problem
the sticker have peeled off and are jammed in the mechanism, if you cant get the whole sticker out by carefully using a screwdriver in the slot , you have to remove the unit and disassemble it., for later, instead of having stickers on cd's,its better to buy a cd marking pen and write directly on the cd
Jan 24, 2010 | 2005 Dodge Durango
What is the recommended tire pressure for a 2009 Saturn Aura? It has 40 PSI on the tires, but that sounds high.
You are right. That is to high. 40psi is most likely the maximum pressure that those tires can handle. Your car has a sticker on it somewhere. This sticker will tell you the proper air pressure for your tires. On a 2009, your sticker should be in good, readable condition. Common places for the sticker are: in the jamb of the driver's door, on the inside of the trunk lid, or inside the fuel filler door. If you cannot find the tire pressure sticker in one of these locations, it should also be in your owner's manual. Those numbers should be near the rear of the book in a section called 'specifications' or something similar. Good luck. Proper tire pressure is extremely important is winter weather.
Jan 13, 2010 | 2009 Saturn Aura
How do I get a sticker off my drum
buy chewing gum remover , or use Ice
Oct 29, 2009 | HP LaserJet 2100 Printer
Tire size for 1987 dodge colt
check the door jam for a sticker. if not check inside the glove box for one.
Aug 06, 2009 | 1987 Dodge Colt Vista Wagon
My swingline electric stapler model 42130 is jammed is there a manual release button the one on the back doesnt work
Taking the stapler apart is a complex task if you can figure how to do that.To dismantle the stapler, slide back the top, remove two small screws on both sides, six on the bottom, four of the screws are under the sticker so you must peel off the sticker, you must also remove the sticker on top. There two tiny shinny screws at the bottom once you are inside. Now you have access to more screws you can take off to get to the staples place where the jam is. Watch cables where they are plugged to in case they come off. If you are are a mechanical technician or technically inclined you might be able to fix this yourself but you must be very patient.
Aug 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Printer not feeding paper properly or at all..
we find a drawing pin in ours - ten points for the "picking upside down and shaking method"!!
Oct 27, 2006 | Dell 922 All-In-One InkJet Printer
OfficeMax 0M96431 Shredder Logo
221 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
