Question about Gigabyte GA-K8N51GMF Motherboard
Two problems:1) Audio2) Freezing when running AMD Overdrive
I have the habbit of whipping clean my HHD and re-format/re-install system and programs every year for the las five with the newest manufacturer's page downloaded drivers. Two problems: 1) Audio & 2) Freezing when running AMD Overdrive - Original setup:Gigabyte GA-K8N51GMF Athlon 64 3200+ Radeon x1300 512 1GB of dual channer ram 300x2 SATA, RAID 0(HalfLife2/FEAR; audio editing, video editing) Realtek's software has a built in eq, not very good but sometimes helped. - New setup:Gigabyte GA-K8N51GMF Athlon 64x2 4200+ Radeon x1300 512 1GB of dual channer ram 300x2 SATA, RAID 0 (HalfLife2/FEAR; audio editing, video editing)Audio is HORRIBLE, phone-line quality. Realtek's built in eq only makes sound worse. AMDOverdrive freezes the system when ran. Advice please?
  • Qualanqui Jan 08, 2008
    PS: I used AMDOverdrive with original setup, never had a problem. Could not over clock, but not a problem.
  • Qualanqui Feb 02, 2008
    Use FAT32 in Wxp with a pair of SATAs adding upto 600GB? :(
    Wxp IS genunine!
    MoBo driver, the AMD dual core driver, then video driver, THEN audio driver is installed.
    C'mon guys... you can do way, way better than that..!
  • 407 Answers
Format your hdd fat32 with xp geneuin. then setup motherboard driver...
Posted on Jan 24, 2008
6ya staff
SOURCE:
Downloading of motherboard driver of amd sempron 3100+1.8 ghz
I understand that you want to download Motherboard drivers for Acer Aspire 3000.
Before I provide you with the link to download the driver, please be informed that the computer is manufactured in 2008, so most of the Motherboard chipset driver is installed withe Operating system. You need drivers files for the below mentioned parts:
1. Audio
2. Bluetooth
3. CPU
4. LAN
5. Modem
6. Touchpad
7. VGA
8. Wireless LAN
Please visit the below mentioned link to download all the above drivers
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=101
or
http://support.acer.com and select the computer model.
Thanks and regards
Jitha
Nov 26, 2011 | Acer Aspire 3000 Notebook
My commputer is very slow could you help me speed it up?When opening a program it takes 10-15 mins gpr a program to open.
You probably have a number of viruses on your computer. My suggestion is to download these two programs and uninstall your current anti-virus software (if any).
AVG Free:
http://free.avg.com/us-en/homepage
AVG is a great anti-virus program that will always be running and protecting you.
Maleware Bytes:
http://www.malwarebytes.org/
You will want to run this free program as soon as you download it. It will remove any viruses on your computer. This is a great tool to use about once a month to make sure your computer is clean. Do a full scan and wait for it to complete. If you have completed the steps above and still have the problem, you will need more RAM. RAM is temporary memory that your computer uses when it is on. If you have very low RAM, then you will have a very slow computer.
May 16, 2011 | Computers & Internet
It is running so slow!! It pauses and screen fades to light color! I cannont do my work!! Help!!
This could be for a couple of reasons, 1) you have a virus causing your laptop to crash or 2) you have a faulty Hard Drive.
Try downloading and running Hit Man Pro (an anti-virus software) that should clean up any viruses you have, download it here:
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-2239_4-10895604&ontId=2239_4&spi=50fbf8256fc023103cca4ba60e4a71b1&lop=link&tag=tdw_dltext<ype=dl_dlnow&pid=11754089&mfgId=6302975&merId=6302975&pguid=CyZLHAoOYI4AAAxmYBAAAABD&destUrl=http%3A%2F%2Fdownload.cnet.com%2F3001-2239_4-10895604.html%3Fspi%3D50fbf8256fc023103cca4ba60e4a71b1
Run the scan and remove and viruses it finds and reboot the computer...see if this makes any difference, if not, try booting up in the recovery partition and repairing Windows.
Let me know if this helps
Mar 21, 2011 | HP Pavilion dv2310us Notebook
My computer is running so slow need help please
Registry Fragmentation Registry is accessed by almostall the installed programs and your operating system itself. Why is computerslow and freezing has to do with the fragmented registry data. You have todownload a PC Optimizer software that includes Registry Defragmenter tool suchas Reginout to perform system maintenance tasks. b> Too Many Programs areInstalled Installing too many programs makeyour computer slow and freezing. You have to uninstall the unwanted programs. 1. Click Start ' Control Panel.
2. Click Programs ' Uninstall a Program.
3. Select a program to remove.
4. Click Uninstall button.
5. Follow the wizard.
6. Reboot the computer after completion. b> Insufficient RAM Sometimes computer runs slow andstarts freezing due to an insufficient RAM. You have to install additional RAMsif required. b> Lack of Proper Configurations You will feel that your computeris slow and freezing if you haven't set Windows for best performance. 1. Right click My Computer.
2. Select Properties.
3. Click Advanced System Settings.
4. Click Advanced tab.
5. Click Settings button under Performance frame.
6. Select the option Adjust for best performance.
7. Click Apply ' OK ' OK. b> Junk Registry Keys Storing junk entries in theregistry makes your computer slow and freezing. You have to delete such junkentries using a Registry Cleaner and PC Optimizer software.
Feb 25, 2011 | Microsoft Windows XP Professional SP2
My computer too slow always get the not responding reply.
Eliminate Viruses and Spyware
Step 1
Run your antivirus program. There may be something slowing your computer that you can remove. It is a good idea to run your antivirus program every week.
Step 2
Remove spyware. Run a good spyware tool at least twice a month.
Step 3
Use a pop-up blocker, if you have one. Check your antivirus program.
Dispose of the Extras
Step 1
Delete your document files for anything you no longer need. Saved pictures, audio and video files in particular can slow your computer.
Step 2
Remove unwanted programs from the Control Panel area. Old toolbars or games the kids downloaded off the Internet are a good place to start. Look for software you no longer use, such as the old printer you threw out last year.
Step 3
Clean out your email. Old messages are a constant drain on your computer's resources. Go through every folder, deleting everything you do not need. Leave no mail! Finish by emptying the Deleted Items folder.
Step 4
Turn off unnecessary programs. Check your taskbar for icons that show running programs. Disable anything you are not currently using.
Run Maintenance
Step 1
Run the Disk Cleanup tool located in your Control Panel. (Windows only. For other operating systems, please check the Resources section below.) This will remove temporary files, cookies and unnecessary components to speed up your computer.
Step 2
Defragment your computer. Defragging takes some time, but will speed your computer significantly. You can find the tool in your Control Panel. Run it monthly.
Step 3
Check for disk errors. Sometimes corrupted files slow down your computer. To find and fix these files, Go to My Computer and right-click on C drive. Choose Properties, then Tools.
Nov 22, 2010 | Computers & Internet
My pc.. desktop is very slow.. its a windows vista
You may want to look into upgrading your RAM if there is less than 2GB installed. This is a recommendation that I have found in working with several PC's running this Operating System. Also, you would want to run disk clean up and remove any temporary files that Windows finds. Deleting any other temporary or unused files from your PC on a regular basis should increase system performance. In addition, if these steps do not solve your problem, you may want to consider upgrading to a faster performance hard drive (preferably a SATA II with a 32MB cache). As a last resort, you may look at your CPU to see if there is an upgrade for it, as well. Keep in mind that Vista is a resource hog and can slow down a PC within just a short period of time.
Oct 15, 2010 | Computers & Internet
Broke system while attempting to overclock with AMD Overdrive
Found this on Biostar's support page:
http://www.biostar-usa.com/knowledgespec.asp?faqid=99977
They recommend unplugging the power cord for 5 seconds. After plugging back in, press and hold the "INSERT" key when booting to reset the CMOS back to factory defaults.
Since you were never able to actually boot with the overclocking, it's doubtful that any damage has been done especially since the MB shut itself down as a precaution.
Best of luck!
Greg
Jun 13, 2009 | Computers & Internet
Error Message???
sound like the hhd is going .
backup all your files to some external hhd or to another computer.
use the Window Xp Cd to reformat eh hhd and reinstall Xp. if the format encounter hhd problem it will stop. in that case, you need to buy a new hhd and replace it. if not the format will go throught, do that twice and reinstall XP.
Jan 14, 2009 | Acer Aspire 5050-3242 Notebook
Duel boot system first xp then vista
Wow....
First I would check the BIOS settings. Make sure that the slave and master jumpers are correct on the drives.
Wouldn't it be easier to make one drive Windows XP on one drive while running Vista on the other?
It would make things easier to troubleshoot.
Jun 12, 2008 | Computers & Internet
Open Questions:
See all Gigabyte GA-K8N51GMF Motherboard Questions
Gigabyte GA-K8N51GMF Motherboard Logo
163 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Ekse
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
