Question about Miele 24 in. G645SC Plus Free-standing Dishwasher
My dishwasher is not draining, everything is cleaned according to the user manual. The dishwasher is 4 years old, used once every day. No abnormal noises. What next?
  • 4 Answers
If your piping is clean, your pump is maybe burn, or maybe a blown fuse, also check for lose connections
Posted on Nov 14, 2009
Hi we have a Kenmore Dishwasher Model # 13744K and it won't turn on. It has water in the bottom that won't drain. Please advise. Thanks. John Webster.
For a dishwasher that was rated pretty high by Consumer Reports, it does not clean very well. In addition, the plastic control button cracked in less than a year and I must constantly clean around the inside of the door ... and I never received my rebate.
Despite those issues, it has been a workhorse. My wife is a daycare provider and the machine is used twice a day (on average) and still runs well. On a monthly basis, I alternate a pint of lemon juice and a pint of vinegar to keep it clean and once per year I use a granulated dishwasher cleaner.
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
The new world dw60 dishwasher goes through the wash programme but on completion the dishes are still not clean we do even rinse all the dishes before we put in the dishwasher but still the dishes are not...
either you have a plugged drain or drain filter or the water may not be hot enough in the washer. If you still have a copy of the owners manual it will also give you further solutions to this problem. If you do not have the owners manual go to the mfgr's website and download copy or call cust service...
Best regards
Ck
Feb 16, 2011 | Dishwashers
After 6 years of once-a-day family use my AEG OKO_FAVORIT 6281i dishwasher starts up OK but a few minutes into the cycle begins flashing error code 20. At this stage there's a litre or two of cloudy water...
The easiest way to empty the dishwasher would be to use a small container and empty most of the grubby water. Then take a towel or two and dry it out.
Now about the error code - does it come back when you turn the power off and on again?
Jul 02, 2010 | AEG Dishwashers
Wont drain check everything push drain botton still wont drain
i call a repairman in it was the drain pump thank you for your help NOT what a joke this site is have a good day boys
May 18, 2009 | Bosch 23 in. SHU33A Built-In Dishwasher
BUZZING SOUND WHEN RUNNING
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Mar 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool dishwasher first 5 years ok last year thermal fuse - again last week - 4 cycles later - at rinse leaves water in bottom but dishes are cleaqn Rob
Your drain is gummed up and it may be the hose too. First remove the trays. Then, clean out everything from the bottom of the inside dishwasher pan. Also clear the drain hole in it. BE CAREFUL THAT YOU DO NOT CUT YOUR SELF ON ANY BROKEN GLASS THAT MAY BE IN THE BOTTOM. Next, go under your sink (or where ever the hose hooks your dishwasher into your drain) remove the hose and clean around both sides of the connections (be sure to replace it exactly how it was to prevent leaks-also check for leaks during and after your first test run). Lastly, run the washer empty using only 1/4 of vinegar. Hope this helps!
Mar 14, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Dec 27, 2008 | GE Profile PDW9880NSS Stainless Steel...
Miele dishwasher g664 12 years old maybe?
if the water drains into a bucket then the blockage will be in the drain spigot under the sink where the drain hose connects.hope this helps.
Mar 14, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
Miele 24 in. G645SC Plus Free-standing Dishwasher Logo
214 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
