Question about HP Photosmart C8180 InkJet Printer
How to replace encoder strip on hp c8180 printer
aomcopier
  • 22 Answers
SOURCE: Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Posted on Apr 01, 2007
Cindy Jo
  • 74 Answers
SOURCE: Encoder Strip
What is the question? Where should you put the numerical strip of ownership? Let me know and I will send you in the right direction.
Cynthia Charczenko
Posted on Jan 15, 2008
damanpreet_c
  • 69 Answers
SOURCE: encoder strip
It is not possible for you to hook the encoder strip back to print, its kind of a Hooks on both ends which is holding it, even if you are able to put it back, it will not work,
I would refer you to a local computer tech, however I'll suggest you to get a new printer, coz tech might charge lot more than what the price of new printer
Posted on Nov 07, 2008
  • 4 Answers
SOURCE: encoder strip part c8941-80005
an encoder strip is seriously easy to replace! the strip rides thru a sensor on the ink cartridge carriage. one end hooks on to a small "hook"" on the left side of the plotter. the other end connects to a small "hook" on the encoder strip spring which connects to the right side of the plotter. Most manufacturers consider anything inside the case to be "not user replaceable". but really, its harder to keep the pictbridge bezel (cover) from falling out than it is to replace the encoder strip.
in response to jktyler.. my 2 year old did the same. if the small slots on the ends of the encoder strip are broken, then the strip is definitely damaged.
Posted on Dec 10, 2008
komguy
  • 2306 Answers
SOURCE: HP 7310 Encoder Strip Replacement
That model has easy covers on the side to remove, 1 screw in the front of each and one in the rear. With side covers off you can see the slot to pass the encoder thru and connect the left side to the spring and the right side to the hook on the frame.
Posted on Jan 18, 2010
When i was replace the trailing cable my plotter writing the system error:86:01 how to solve
86:01 fatal error code resetable with power cycle- error is down to encoder not reading/ blockage on media path - encoder strip missing
1. clean and clear accuride rails ( long silver bar )
2. Clean or replace encoder strip
3. clean or replace encoder sensor
if all else fails contact Belmonte.co.uk for fast response
Jan 02, 2013 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
My Hp z6100 carriage jamms in the middle along the encoder strip during printing and gives me error 86:01. I have tried cleaning the encoder strip and still having the same problem
Maybe u need another encoder strip If u dammaged the strip while cleaning.I've cleaned mine only once with water and a soft a wet clout.Cleaning must be verry gently
Jul 29, 2011 | HP Designjet Z6100 InkJet Printer
87:10 error in HP plotter 1110
There is a problem finding the Scan-Axis encoder reading.
1st thing to do is upgrade the firmware (www.hp.com)
Try cleaning the Encoder Strip.
If that fails the encoder strip will have to be replaced.
Mar 03, 2011 | HP Designjet T1100ps Printer
THE PRINTER CARRIAGE GOES TO THE RIGHT AND WILL NOT RESET, THE YELLOW LIGHTS COMES ON, AND THE ERROR MESSAGE SAYS PRINTER CARTAGE IS STUCK.
It may be that the encoding sensor or encoding strip may be dirty or damaged. The encoding strip is the striped plastic strip found just behing the print carriage, The encoding sensor is located on the carriage and reads these stripes to establish where the caridge is. Try wiping the encoding strip with a damp clotch, be carefull not to use chemicals or too much preasure as this will damaged the strip.
Dec 09, 2010 | HP PSC 1510 All-In-One InkJet Printer
Encoder strip for HP 2175 xi
Here's the solution for fixing a carriage jam on your PSC 2315xi printer. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042632&cc=us&lc=en&dlc=en&product=90812 But, you said the encoder strip came off. I always understood that if the encoder strip came off, the printer was dead. I've never tried to take the encoder strip off and put it back on again to see what happens. The encoder strip is what tells the carriage where it is. Without the encoder strip, the carriage doesn't know where to go.
Jun 09, 2009 | HP Office Equipment & Supplies
Hp c5280 strip encoder part #c9058-80029
Damampreet,
In all due respect, I have known a couple of people who have placed their encoder strips back on their printers and had no problems with it working again.
Jan 14, 2009 | HP Photosmart C5280 InkJet Printer
Printer problem
its a problem of the encoder strip . either the encoder strip is loosened or damaged.the carriage sensor reads the plastic encoder strip while it moves.if the sensor is not able to detect the encoder ,such a problem arises.u can check the position of the encoder and take the necessary step accordingly.if the encodder is damaged replace it.
good luck.
thanks.
Oct 27, 2008 | HP PSC 1410v All-in-One Printer
Hp g85 all in one
The "plastic strip" is the position encoder of the print head, it holds itself in place by two latches, one is fixed and the other is flexible, you have to put the encoder in the flexible latch first by holding it at an angle and then in the fixed one, probably you'll have to disassemble the MFP to have access and a better view of the parts.
Apr 27, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Strip encoder 7410 hp all in one printer
Not sure about the smoking thing...to replace the encoder strip will require fairly extensive disassembly. There are no repair manuals available for any of HP's Inkjet machines because all repairs or replacements are depot repairs (u send them in). We service all of their machines. We have an extensive used part inventory where we are able to fix most all of their inkjet line. If you were to bring this machine in to our shop, the repair would cost you $65 if its only replacing the encoder strip.
Inkworks
866-381-0541
Mar 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Encoder strip part c8941-80005
Feb 24, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP Photosmart C8180 InkJet Printer Logo
218 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
