Question about GE Refrigeration Profile CustomStyle 22.6 Cu. Ft. Side-by-Side with Refreshment Center - PSC23SHT...
GE Profile Arctica Refrigerator has lights on intermitently but the panel which adjusts the temperature won't accept input changes. The actual LED displays only flash on momentarily and it is most definitely out of warranty. The refrigerator itself is not cold nor is the freezer. Although hooked up to a water line, it doesn't dispense water. It has been sitting in a vacant home for most probably a year and I would imagine the power has also been off at times. No way to be sure. I am buying the home and trying to determine if there is an easy way to determine if I should spend any time trying to fix this or if I should just have it hauled to the curb.
  • GE Master
  • 1,606 Answers
I would suggest replacing the main control board . This board is on the back of the refrig , behind an 8 " X 10 " panel . If that doesn't work , dispose of the refrig . ( but I think it will )
Posted on Nov 14, 2009
GE Profile Arctica fridge running too cold
You may want to check your damper assembly to see if the door is broken. If the door is broken it will air to migrate to the refrigerator compartment causing freezing issues. Also check to make sure that the damper door is not staying open. When you take the cover off with the door open the damper should close. If the damper is open then you need to replace the damper. Here is the damper to order.
Dec 05, 2012 | GE Refrigerators
I have a GE Profile Arctica Fridge. The temperature in the Freezer has dropped to 34 degrees and the Fridge has dropped to 40. The fridge is running and is blowing air in the freezer, but not really...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE Profile Arctica Stainless Steel Top...
Chasnge light for water dispenser
Dispenser
Unplug the refrigerator.
The bulb is located on the dispenser
under the control panel.
Remove the light bulb by turning
it counterclockwise.
Replace the bulb with a bulb of the
same size and wattage.
Plug the refrigerator back in and you are ready to go!
Thanks, Sea Breeze
Apr 25, 2010 | GE Profile Arctica Stainless Steel Top...
GE Artica, pulsing lights
Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00 .
Dec 09, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE not cooling properly
If you have changed temp and adjusted vents, then either your temp sensor may be faulty or thermostat itself may be faulty. Check compressor to make sure it is pumping and there is no freon leaks.
Jul 09, 2009 | GE Profile Arctica Stainless Steel Top...
Ge profile arctica light not on for filter and is not making ice
change filter first if light stay on after changing filter change icemaker
Mar 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE PRofile Arctica
Just had mine with the same problem fixed today,it was the main board on the rear of the fridge,common problem with these models told by the tech.
I believe you can get a free board fom ge but you pay labour
Jun 17, 2008 | GE Profile Arctica Stainless Steel Top...
GE Refrigeration Profile CustomStyle 22.6 Cu. Ft. Side-by-Side with Refreshment Center - PSC23SHT... Logo
219 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
