Question about GE Tritonr XL GSD6260JCC Dishwasher
Cycles randomly change electronic panel seems to
Cycles randomly change; electronic panel seems to be malfunctioning and sort of going nuts!
I am having the same issue. It randomly cycles back and forth between cycles and never shuts off on it self. Before I go replacing parts I hope to get some advice what I should try first. Please help.
Posted on Nov 27, 2009
Plasma tv randomly goes black
By the highly technical manner in which you set forth the problem, I can see you are far more electronically savy than am I, BUT just a thought: Is there there any sort of timer setting in the TV menu which may be cutting it on and/or off, and which you have somehow failed to notice? Good luck. . .
May 22, 2016 | LG 60PN5300 60" Plasma TV 1920x1080, 600...
2002 Liberty 3.7 Recent new heads, coil packs, plugs. At dealer compression OK , leak down test OK. was running perfectly then random misfires, spark advance jumping from 0-17 at idle.. At speed all is...
you must RUN the scanner/computer for better diagnostic. You can have fuel system malfunction, detonation, valve noise, valve adjustment is set too tight, , intake manifold system is leaking.Engine fuel pump is defective+pcm (ignition system).In short the electronic is complicated now in vehicles.
God bless you
Jul 31, 2013 | 2002 Jeep Liberty
LG 42LB4D Pixelated lines across screen
It sounds that the digital video processor section has some malfunction. The set need through check up. Working with digital circuits, need sound knoledge in digital electronics, and expereince to do the work.
May 12, 2012 | LG 42LB4D 42 in. LCD HDTV
Kenmore elite HE31 front loader will not start but has power
This seems to be a problem in the start switch diode. If all works fine, but will not push and start and all cycles seem to work when working it manually, this is in the switch timer electronic diode is not working properly. Sometimes a code will not come up, because cycles are still working when manually changing wash cycles. There is seperate switch or electronic trigger that starts the machine, and has probably worn out or not making good contact. If you can unplug machine and then take off panel, trying spraying behind start switch with electronic cleaner to free up any possible dust or dirt. Might get lucky.
Apr 07, 2012 | Kenmore Elite HE5t Washer
Hoover washing machine - door won't open and drum won't spin, error displayed is e08, ideas anyone? Thanks :-)
1. please provide the model number for the washer
2. this is a timer error code and it seems that it locked the door during the spin cycle.
There may be a malfunction sensor or you will need to unplug the washer to reset the washer to complete the cycle.
Something electronic has caused the washer to shut down to protect the electronic circuit. You may have a defective timer.
Mar 13, 2010 | Washing Machines
Oven seems to have some sort of electrical problem
I just solved a similar probelm with my Kenmore oven, gave error code f7, among others. The control panel is manufactured by General Electric. Turned out that the control panel has a electrical ribbon that goes to the relay panel. The ribbon is actually two ribbons pressed together. They should easily pull apart. They are not insulated properly, and the ribbon leads short together or cross. Just put a piece of paper between them to act a an insulator. Good luck!
Nov 08, 2009 | Ovens
Kenmore Elite Oasis Model# 110.27087603
I had a very similar problem with my Oasis He Washer 110.27087603. The machine was randomly cycling through different water temperature indication lights. It would repeatedly beep and not allow a wash cycle to complete. Fixya.com alerted me to the "upgrade" to the electronic control W10112112 to W10189966. My machine was scheduled service and a Sears tech replaced that board. My problem with random cycling continued and the tech stated the touch panel electronics; part # 8564392 would fix the problem. He said one of the microswitches on the panel was probably stuck and not allowing the machine to enter a wash cycle. I found the 8564392 panel at http://www.prosupplyco.com/search.aspx?find=8564392 for a very reasonable price. Realize that Whirlpool parts are Whirlpool parts and Sears doesn't hold the only key to them.
Oct 29, 2008 | Washing Machines
CDA-9855R - Sound setting constantly changes
It's possible the stereo is in some sort of "demo" mode. To verify this setting, go to Menu-->Demo and set it to "Off".
Feb 18, 2008 | Alpine CDA-9855 CD Player
GE Tritonr XL GSD6260JCC Dishwasher Logo
130 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
