Question about Princeton Digital VL1916 19" LCD Monitor
Hi my pc monitor keeps turning off & on, why and how do i fix it???
  • 11,361 Answers
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
Old Dell 8250 screen don't turn on at all. power light keeps flickering
Hi Natalie,
It sounds like the monitor has come to the end of its life cycle....You can verify that the monitor is bad by connecting it to another PC or Laptop using a VGA monitor cable, and seeing if it does the same thing.
Gary
Oct 28, 2013 | Dell Dimension 8250 PC Desktop
My E-machine E3031 keeps turning its self off what can i do
you have a problem with your PSU (Power Supply Unit) I had this same problem with this exact same PC & Once i replaced my PSU it solved this problem, check eBay for people breaking this PC & Bag a bargain, Mine cost me 23 GBP & was fitted in no time check online for details on how to replace the PSU.
Sep 21, 2012 | E-Machines eMachines Desktop PC
Auto adjustment in progress keeps popping up
Try turning down the brightness on the monitor, sometimes this will fix the issue, if not the problem is in the inverter board and needs a professional to assess it further.
Mar 10, 2012 | HP w1907 LCD Monitor
When fisrt turning computer on monitor shuts down ,have to keep turning it off and on until it finally stays on
Check the cable connections [VGA & power] and ensure they are properly connected.
Try switching the power cables with the PC and see how the monitor fairs.If it properly operates with the PC cable,then replace its cable.If there's no change, take the monitor to a repair shop and have it fixed.
Hope this helps.Thanks!
Please rate this answer.
Oct 27, 2011 | Computers & Internet
I have a Gateway HD1900 monitor. The problem i'm having is, at start up the monitor turns on for a sec. then off for a sec., over and over. This keeps the screen black. After about 15min. or so, the...
it is possible the monitor is going out
another possiblity is monitor setting--when the monitor comes from the factory they put setting in for the monitor, & you have to go in & adjust them to what you want
Windows 7
Go to control panel
Go to hardware & sound
Go to power options
Select a power plan
Which ever one you pick--click change power settings--to what you want the settings to be
And go to each power plan so the settings will be the same
Each time click save
For windows xp
Go to the control panel
Go to appearance & themes
Go to screen saver--at the bottom you will see monitor power--to adjust monitor power settings & save energy click the power button
The menu will say power option prosperities
Turn off monitor setting--click what you want it to be
Turn off hard disk settings--put what you want
Turn off system standby--put what you want
Sep 16, 2011 | Computers & Internet
Hi I am Nithya form Bangalore, India. I bought an Acer CRT monitor (14" inches) 4 years ago. I am facing a problem with it since the last 2 days. I am unable to view the picture clearly, only part of...
Hi Nithya
Try this Turn off the monitor then unplug all the cables , press and hold down the power button for 15 sec , see whether there is any magnetic device near by the monitor , eg Anything which is made of Iron, or any metal, keep them away from the monitor , if this is not fixing the issue , i Guess the monitor need to be serviced !
Nov 09, 2010 | Acer Computers & Internet
My monitor keeps going to sleep & can not get computer on. What's wrong & how do I fix it ?
it could be the monitor VGA cord is not properly connected to the PC and the VGA Port on the PC is faulty. Try use the monitor on another working PC and see if the monitor displays, if it displays then your PC VGA cord is bad or the display resolution in the PC is too hight. Or if the monitor does not gives the same problem, replace the VGA cord.
Jan 30, 2010 | HP w1907 LCD Monitor
My 21inch Samsung monitor screen keep turning black
try another monitor to make sure that the problem is not as a result of there being no output from the system unit
Dec 22, 2008 | Dell Inspiron 531S (DDCWGA1_5) PC Desktop
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Princeton Digital VL1916 19" LCD Monitor Logo
174 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
