Have an Chrysler Corporation central station air
Have a central station air handling unit (AHU) to reuse for HVAC for a client. Nameplate data:
Max rpm 1200
Airtemp Division
B1605-003
Model # BD29
Ser. # 5B112036
Pimser # No.
Dayton, Ohio
Have any idea where I can find CFM and static press. info on this?
Owner found the original set of design drawings. Added up the total cfm of the outlets, and modelled the duct system to find the design static pressure. At this stage of it's life, we're limiting the AHU to only 3/4 of design load.
Posted on Nov 16, 2009
Unit has no power, we had a power outage, power coming to unit is good.
Break A Breaker No Power To Air Conditioner Tripped AC ...
? 5:08
https://www.youtube.com/watch?v=nS2pBg2QbnM
Jun 2, 2013 - Uploaded by KungFuMaintenance
Break A Breaker No Power To Air Conditioner Tripped AC Can I Get A ... I have a GE model # AEM14aQL1 air conditioner wallunit 14,200 BTU ...
HVAC HELP! Unit has no power and Fan, Heat and AC are all ...
www.city-data.com > City-Data Forum > General Forums > House
Jul 1, 2012 - 10 posts - ‎8 authors
Now, when I attempt to turn on the AC I get no response from the unit. Nothing is blowing out of vents, even when fan mode is set to on. So far I ...
No power to outside AC unit - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 5, 2005 - I have an outside AC unit that appears to not get power. The circuit breaker is OK, and the fuse "appears" to be fine, but do not know if there is ... A/C problem, thermostat has no power
Aug 5, 2009
central a/c unit has no power
Sep 29, 2004
More results from www.doityourself.com
Dec 29, 2015 | Heating & Cooling
I just installed this unit and can not get the blower to run
Seriously depends on what unit you have. Model # & serial #? You can "jump" R to G at the unit. If its a standard Goodman AHU there may be a terminal block or just some wires that were factory installed outside of the unit. R to G will send 24v to the blower relay, sequencer or board (depending on model) energizing the relay and then returning to common. If you have tried that you should ensure you have proper line voltage 220-240vac. at the service breakers on the AHU.
May 18, 2015 | Goodman Manufacturing Goodman GPH1330M41...
Comfortmaker 10 HVAC output size?
Comfortmaker 10 means simply it is a 10 SEER system. Unable to determine the OUTPUT size without the Model Number. Go to the Outdoor Unit Nameplate and locate the Model No. Here is an easy way to determine the "SIZE" of the "Comfortmaker 10 HVAC" Systems:
Model No.: OUTPUT Size (Nominal Tons of A/C):
NAC015 1.5 Ton Unit
NAC024 2.0 Ton Unit
NAC030 2,5 Ton Unit
NAC036 3.0 Ton Unit
NAC042 3.5 Ton Unit
NAC048 4.0 Ton Unit
Aug 30, 2014 | Heating & Cooling
My corona air conditioner inverter does not produce hot air
these are all in one units, some of them are made like smaller central units and some of these are separate ac and heat units. the heat in the separate ones is run off of a heat strip in the unit it's self the ones that are made like a central unit reverse the flow of the freon in the system to draw the heat from outside. this is not something you can repair very easily yourself. most places require because of the freon that you have a certified HVAC technician to work on them.
Feb 22, 2013 | Heating & Cooling
Can you use a 410 AHU with a r22 condensing unit
Yes you can if the 410 a/h is new just put a r22 txv on it I have personally done hundreds of them mainly carrier they even sell the conversion txv.
I'm a 15 year hvac sub contractor and I know my sh##
Apr 09, 2012 | Carrier 38CKC036 Air Conditioner
Address for vermont american tool corp
US Headquarters:
Robert Bosch Tool Corporation
Accessories Business Unit
1800 West Central Road
Mount Prospect, IL USA 60056
Telephone (224) 232-2000
Canadian Headquarters:
Vermont American Canada
1226 Cardiff Boulevard
Mississauga Ontario L5S 1P6
Telephone (905) 564-1155
Global Headquarters:
Robert Bosch GmbH
Power Tool Division
Max-Lang Strasse 40-46
70745 Leinfelden Echterdingen
Germany
Jun 05, 2011 | Garden
I have a 04 acura and the lights in the radio clock an heat controls does not work.
ACURA Service Bulletin
04-021
Applies To: 2004 TSX - From VI N JH4CL9...4C000001 thru JH4CL9...4C028982
July 9,2004
Audio-HVAC Display Module Is Dim or Dark
SYMPTOM
The audio display and controls (knobs, buttons, bars)
of the audio-HVAC display module are dim or are dark.
PROBABLE CAUSE
Faulty audio unit.
CORRECTIVE ACTION
Replace the audio unit. Refer to S/B 87-015, Audio Unit
In-Warranty Exchange/Out-of-Warranty Repair.
If a client calls ahead to schedule an appointment, and
the vehicle is in the affected VIN range, order the
remanufactured audio unit right away so it is available
when the client comes in.
PARTS INFORMATION
Order the appropriate replacement audio unit:
NOTE; The audio unit is listed as a Tuner Assembly in
the Interactive Network (/N) Parts Catalog. This unit is
both a tuner and a 6-disc CD changer.
Tuner Assembly (without navigation system):
P/N 39175-SEC-A02RM
Tuner Assembly (with navigation system):
P/N 39175-SEC-A82RM
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies
Operation Number: 010149
Flat Rate Time: 0.5 hour
Failed Part: Use the RM part number (from the
repair order) without the RM.
Example; 39175-SEC-A01
Defect Code: 03214
Symptom Code: 03272
Skill Level: Repair Technician
Out of warranty: Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
decision, before starlina work.
REPAIR PROCEDURE
1. Go to S/B 87-015, Audio Unit in-Warranty
Exchange/Out-of-Warranty Repair, for guidance on
how to get the remanufactured audio unit.
2. if you can read the audio display, write down your
client's radio station presets.
3. Remove the audio-HVAC display module (see page
22-267 of the 2004 TSX Service Manual). (In ISIS,
use the keyword DIS MOD, and select Audio-
HVAC Display Module Removal/Installation frorn
the list.)
4. Remove the faulty audio unit from the audio- HVAC
display module (see page 22-268). (In ISIS, use the
keyword DIS PAN, and select Audio-HVAC
Display Panel Removal/Installation from the list.)
5. Transfer the left and right brackets from the faulty
audio unit to the remanufactured audio unit. If the
remanufactured unit has a shipping cover and
shipping screws, make sure you transfer them to
the faulty unit being returned.
6. Install the remanufactured audio unit in the audio-
HVAC display module. Then reinstall the audio-
7. Enter the anti-theft code for the new audio unit.
Enter your client's radio station presets if you
recorded them in step 2.
8. Make sure all of the functions of the audio unit and
HVAC work properly.
9. Replace the sticker on your customer's anti-theft
radio identification card with one of the new stickers
that show the anti-theft code. Apply the other
sticker that shows the anti-theft code onto the
vehicle history file copy of the repair order.
10. Remove all old serial number stickers from the side
of the glove box or inside the center console. Then
apply the new sticker that shows only the serial
number to the side of the glove box.
11. Return the faulty audio unit to the parts
department. Refer to S/B 87-015 for parts return
in structions
Jan 29, 2010 | 2004 Acura TSX
Hi there i have a toshiba single phase split system that keeps tripping the breaker after about a week of running i have checked the pressures the running current the fans an the coils an eveything is...
Check and see if it is correct size breaker. The breaker may be weak. If your amp draw is ok and the units starts ok. You may have a loose connection on the breaker or a bad breaker they do get weak over time. On the outside unit there will the correst breaker size min and max on the nameplate. Keep in touch Rus.
Nov 21, 2009 | Ruud Central System Air Conditioner
I'd like to see if I can get a replacement blower motor for my central air unit that runs at a slower speed.
The central air units are designed to run at a specific speed (100%) if its older unit. The problem with putting in a slower speed motor(2speed) is the unit will still run at max speed. (nothing to regulate the speed). If you contact your local HVAC shop its possible they may be able to convert your unit (but I doubt it). They do have new units that run at 2 speeds when demand is low and run at a higher speed when the demand requires more cooling. Check this link out. Has a little more info. http://www.air-conditioners-and-heaters.com/two_speed_central_air_conditioning.htm
Aug 16, 2009 | Heating & Cooling
Central air and heating being installed
2.5 ton should be able to handle up to around 1750sf house. Price looks good especially if having to do ductwork too!
Jun 15, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
