Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
How do you clean coils under the refrigerator
  • Amana Master
  • 43,501 Answers
There are a couple of ways that I clean the coils. Mostly it depends one the amount of room there is. If I can get a shop vac. with the small crevice tool in there I use it because it does not make such a mess as the other way. The other way is to use compressed air to blow the dust and dirt out and then vac it up. If you can use the vac and go in from both the front and the back to get the most out possible.
Posted on Nov 14, 2009
Testimonial: "Here is the deal---these damn coils need to be cleaned and if they arn't it's a real problem. Like wise you must clean your PC that is sitting on the."
The refrigerator stop getting cold, the ice maker is not being used so that canot be the problem, what do you think it could be.
Adjust the thermostat inside the refrigerator to a higher number setting. The higher the number, the colder the temperature inside. Clean the condenser coil. It is either on the back or under the refrigerator. Clean it by vacuuming the coil. Remove the plastic grill that is under the front door to gain access to the coil. It just pulls off. If these things do not help, the sealed system is low on refrigerant. You will need a repairman to add refrigerant to the sealed system.
Aug 12, 2015 | Refrigerators
How do I clean the coils underneath my Frigidaire 26 cu ft side-by-side refrigerator?
Hello friend, thank you for your post!
I see that you want to clean the coils underneath your Frigidaire refrigerator. The best way to clean the coils is to remove the toe grille and use a vacuum extension brush to reach the coils. I hope this is helpful. -Matt
Sep 12, 2014 | Frigidaire Refrigerators
Why is the line freezing back to the compressor
Probably a defective evaporator fan. Are the temperatures inside the refrigerator abnormally high (particularly in the fresh food compartment)?
If the evaporator fan isn't the problem, try cleaning the coils, usually situated under the refrigerator. Dirty coils often exhibit the same symptoms as more extensive electrical or mechanical problems. The bottom coils of your refrigerator should be cleaned at least every couple of years.
Mar 17, 2013 | Refrigerators
GE Appliance Fridge
The clicking noise is likely the compressor overload tripping.
Here are some tips that may help solve your problem:
  • You will need to clean the condenser coils under the refrigerator. Unplug the refrigerator to completely disconnect electrical power. Carefully remove the cardboard cover at the bottom of the back panel of the refrigerator to access the coils and clean under the refrigerator. To thoroughly clean the coils, I recommend that you obtain and use a coil brush. It is a long, round brush with a handle designed for cleaning refrigerator coils.
  • Check your condenser fan to make sure that it is running when the compressor is on. If not, this could be causing your problem.
  • Be sure to replace the cardboard cover on the bottom of the back panel of the refrigerator. If this cover is not in place, air will not flow over the coils properly.
  • Re-post with your findings.
Oct 17, 2012 | GE 20.3 cu. ft. Bottom Freezer...
How do you clean coils of a Whirlpool side by
Here is a tip that I wrote about how to clean those coils..
RefrigeratorCondenser Coil Cleaning Refrigerator Repair
heatman101
Jul 08, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Is there a way to clean the coils under my Kenmore refrigerator? I have used the vacuum cleaner to get as much as I can, but I can only clean the front of the coils.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
The frame of the refrigerator - behind the door - is very hot i am thinking it is because it hasn't been cleaned under how do you clean under the refrigerator
Hi, On some refrigerators part of the condenser coils are inside of the back and that will make it very hot...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Nov 25, 2010 | Whirlpool Refrigerators
How can I clean all of the coils under the unit? I took off the front cover but can only access the first set of coils.
take the cover off the back...
Lota of stuff to clean there..
Clean the fan too..
Dont forget to rate well ;o)
Aug 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Amana side by side coil cleaning
removethe lower kickplate , under the doors, then with a refrigeration coil brush(avaailable at te hhradware stores) and a vaccumm you can clean the coils
Feb 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
383 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
