E4-01 is the fuser not heating up in time. It can happen after paperjams, and usually it is no big deal. A reset of the code and you might be good to go. Go in to service mode: Function + Original Size + 3 Hit 9 for F9 mode Scroll 'til you see Ram Initialization and enter there Look for an "LBP Fuser Reset" option. Choose that and it will then ask you to turn the power off and back on. If the code comes back up then you have a blown thermistat or thermal fuse. You'll have to pull the fuser out to take care of it, but you'll want a tech to come out and do that.
There is a chance that you might have pulled out a sensor when taking out the jammed paper. E codes are normally not an end user fixable problem. I am sure you have tried switching the unit off and on. Panasonic units sometimes have two switches for turning the unit off - one on the left side and another at the back of the unit.
I will try to see if I can find out the specific E04-01 code
Thank you for your reply. The model is a Minolta EP1031F and I have been placing the original on the...
(More)
Thank you for your reply. The model is a Minolta EP1031F and I have been placing the original on the glass but I also get it when I use the automatic feed. The line is about an eighth of an inch wide along one edge and is solid black.
When I use XEROX Docucolor 2240 from time to time I get a stain on the top of the landscape oriented...
(More)
When I use XEROX Docucolor 2240 from time to time I get a stain on the top of the landscape oriented A4. Everything is clean and really can not understand why. The problem exist in 80 to 250 gr paper. It seems that the printer stores some towner and puts it out when he wants.
Our scenario: About 12 BizHub's C253 configured to do IP-Adress-Fax over our intranet WAN (MPLS)....
(More)
Our scenario: About 12 BizHub's C253 configured to do IP-Adress-Fax over our intranet WAN (MPLS). Most of the time everything works well, but sometimes, a job can't be transmitted and the bizhub keeps it with status ''sending'' in the output-queue. All later faxes keep waiting for that blocking job. The job blocks forever... no timeout. The receiving Bizhub is still able to get jobs from others, so it can't be the source of the problem. If i remove the dangling job, all remaining jobs are sent immediately without any problem.j Users don't get notified about the blocking job, so they realize this only after the recipient calls back, shouting about waiting so long... Any hints?
I need a manual for the copier part only for my DP 2000. It is not used as a printer, and I do not...
(More)
I need a manual for the copier part only for my DP 2000. It is not used as a printer, and I do not need to know about that part of it. The console says that the battery needs to be replaced. I need to know where the battery is and what it does. Also, need to know how to set the console to duplex copies.
