Question about Toto Carlyle 1-piece Elongated Bowl Toilet
How can I tell if I have a G-max system on my Todo
How can I tell if I have a G-max system on my Toto toilets?
    Problem Solver:
  • 5 Answers
The flapper in the tank of the toilet will be oversized, approximately 4" diameter compared to 2.5" diameter.
Posted on Nov 14, 2009
How do I get the water to stop filling the tank on my toto ST794S toilet?
there should be a screw adjustment on the ballcock or fill assembly...screw that down some to adjust...that regulates your tank water level....that screw goes in or out to adjust...one or other should do the trick...may have to do this a few times to get proper adjustment...good luck..
Jul 07, 2014 | Toto St794s-12 Nexus Tank With G-max...
I have a toto duel Max toilet and the water leaks out of the bowl slowly. By the end of the day, I will have no water. Please help
Check flushing mechanism at the bottom of tank to check if it vopens and closes securely. and nothing blocks it.
Jul 27, 2013 | Toto Aquia II Dual Flush Toilet
No water in tank
Check to make sure the valve that goes from the back of the toilet to the wall is open.
May 31, 2011 | Toto Toilet - Elongated Bowl, Dual Max -...
I think our Toto toilet has a G Max valve in it and it doesn't shut off when the tank is full. The flapper seals fine and the water just runs over the overflow tube. Where can I get a diagram of the valve...
If the G-Max valve is not shutting off, just pop a new assembly cap on it.
They are about $2.50 at Lowes.
Even a homeowner can replace the part without tools in less then a minute.
Jan 29, 2011 | Toto MS853113S#11 UltraMax Round Toilet,...
Where can one buy parts to repair the G Max fill valve?
Without knowing where you are located it's impossible for me to tell you where to go that is close to you but here is a toll fre number of a company that I have done buisiness with for. years and they are a toto dealer.They are good people and I'm sure they will do teir best to help you.1-800-748-7226. Good luck and thank you.
Jan 19, 2011 | Toto MS853113S#11 UltraMax Round Toilet,...
Replace flapper valve in ultramax
Your Toto has the "G-Max" flush valve system. The Korky/Lavelle folks have a carded replacement flapper #2021BP for it. It is red in color and the only generic flapper that will work on your toilet. While it may look the same, do not confuse it with the blue flapper #2022BP. Known as the PowerMax flapper, the blue color is to distinguish between the two and the flappers are totally toilet specific. Let your fingers do the walking and locate a hardware store near you that carries the Korky/Lavelle brand or it can be ordered online from several places using the part number for your search word.
If the fill valve ever stops filling correctly, the Lavelle "Quiet Fill", #528BP, is what Toto uses in most of their toilets.
Nov 09, 2010 | Toto UltraMax One Piece Toilet, 1.6 GPF -...
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
Toto toilet ultra max flush
Open the tank and examine the linkages between the handle and the flapper. If the handle is sticking, it sounds like there may be either mineral buildup or a stuck chain.
May 27, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Jan 05, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Toto Carlyle 1-piece Elongated Bowl Toilet Logo
209 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
