Question about Samsung AW1893L Air Conditioner
Blowin warm air, filter cleaned
Brivis ICE series, Filter cleaned, when air conditioner on, blowing warm air. Not refridgerating air?
  • Anonymous Mar 14, 2014
    how to clean filters of TGM inverter air conditioner
  • Samsung Master
  • 3,051 Answers
Hello there:
There may be a small leak in the compressor that may have leaked out the refrigerant or on of the lines may have a pinhole leak in it
I would first have the unit recharged using a recharge kit and than check for any leaks also make sure that all of the fins on the compressor in the back are not damaged and are clear if you have a water howe spray the entire back down real good and if none of this helps than i would susspect a faulty temperature regulator or switch ok?
so please try all of these things that i have mentioned and let me know how this goes for you
Best regards michael
Posted on Nov 14, 2009
  • 6,927 Answers
The compressor may not be coming on,see if it is humming,and if it is,the compressor maybe bad,or out of freon.If it is not running(compressor)then the thermostat maybe bad.
My air conditioner does not blow cold air what do I need to do
Check the filter to see if it is dirty. This will sometime cause warm air to blow out. Cleaning the filter has worked for me.
Here is a link for other items you can check.
Why is My Air Conditioner Not Blowing Cold Air FAQ Service Champions
Jul 20, 2016 | Heating & Cooling
Warm air
could be several things...if all is working/blowing and its clean inside & outside with a clean filter then more then likely it's low on gas/freon......if you continoue to run it it'll pobly ice up/freeze......also make sure you hear the compressor running as well as the fan blowing. sometimes this can be tough listen for that deep rumble/humming sound thats the compressor.
Jul 08, 2010 | Frigidaire FAC126P1 wall/window Air...
Wont blow cold air
First check and clean the filters, and the evaporator coil. (thats the "inside" coil that has the indoor air sucked through it, cooling it and then pushing it out the vents.
If the filter is clogged or the coils are dirty, it will not cool properly and potentially freeze up.
Also check the condensor (outdoor) coil, if it is dirty/clogged, it will run hot and not cool properly.
If all coils and filters are clean, and the fan motors are running and in good condition and it is still not cooling then you are likely low on refridgerant. (handling/purchasing refridgerant other than R134A requres a CFC certification by law)
Aug 20, 2009 | Heating & Cooling
Dometic Air conditioner model 57915-531 blows hot air
Have freon and compressor checked out, could also be bad capacitor
Aug 11, 2009 | Heating & Cooling
Why is my window unit just blowing warm air? the filter is clean,
Shut the lever to outside resiculation air.
Put the fan on slow,
Clean the filter and the temp probe in front of it
Vitally
Jun 02, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
PAC L90 LT thermostat not working, unit icing over
No that would be either a dirty filter/coil ir low refridgerant if it's freezing in cooling mode.
Clean/replace the filter, clean the coil and if it keeps doing it, have a technician who is EPA certified for servicing systems with refridgerant to look at it/add refridgerant.
Mar 24, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Samsung AW1893L Air Conditioner Logo
183 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
