Question about Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum
The hose will ****, but not the main unit - Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum
Empty the dust canister and clean out the bottom filter
Posted on Nov 14, 2009
Power nozzle will not turn on
Depending on the power nozzle model, does a red light come on the top of the power nozzle? If it does, then the problem could be the circuit breaker. If it does not, then the problem could be either in the hose or the connection from the hose to the main unit. Make sure you hear to clicks and the hose is connected solid to the main unit. Otherwise, the receptacles can't make contact to allow the power nozzle to turn on.
RainVac
www.rainvac.com
800-523-0510
Sep 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Electric hose on rainbow not working
Be sure to have a solid connection and that you hear two clicks when connecting your electric hose to the front of the main unit. If this connection is not solid, then the receptacles can not make contact. Try bypassing the hose and plug your power nozzle directly into the front of the main unit to confirm that the hose is the issue.
RainVac
www.rainvac.com
800-523-0510
Aug 06, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Hi! My central vacuum has worked perfectly until just a couple months ago. I went to plug the vacuum in and it didn't automatically start the suction. When I clicked the switch to the right on the...
It sounds like you may have a bad hose. Plug the hose into the wall but rotate it 90 degrees from the normal position. This will bypass the switch on the hose. If you look at the wall end of your hose, you will see a metal band around it. That metal band is split into two sections. You are trying to plug in the hose so that the separation of the two pieces of metal is not lining up at the top of your inlet. If your vacuum turns on then you have a bad hose. It is possible that you have a bad switch in the hose, but it is more likely that you have a bad hose.
If your vacuum does not turn on, then you may have a break in your low voltage wire somewhere. You can check to make sure it didn't get disconnected at the unit. If the wire is connected then try to cross the low voltage wire from the relay at the unit with a small screw driver. If the unit does not turn on you have a bad relay.
If it is the relay, AirVac does not provide them. You would need to consider buying a new unit.
Jul 17, 2011 | M&S Systems AirVac AVP1200 Platinum Series...
Why has air suction pressure has dropped off to almost no suction? Filter cleaning did not help.
Do any of the ports have greater suction than others and are they closer to the vacuum motor unit? You appear to have a piping clog and locating it's position is the primary problem. If you have a portable vacuum, try placing it's hose in the exhaust port of the main unit and insert the pickup hose in a wall port near the main vacuum so that both units are on. The combined suction may pull the clog loose and draw it into the filter of the main unit. The other remedy is to remove the piping from the main unit and see if suction is good at that point, then work your way out to the nearest wall port. Hope some of this helps!
May 24, 2010 | Electrolux Central Vacuum
I'm not getting suction out of the main unit
clean all of the filters, and remove the hoses and shake them, and try to stick something all the way through the vaccuum hose (broom handle or garden hose works great) and then see if it works better. If not, be more specific.
Aug 18, 2009 | Bissell Vacuums
No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
May 05, 2009 | Electrolux Central Vacuum
Main unit wont **** up water but hose does, is there a clog some where and if so how do i fix it.
hello your problem could that you have a clog in the front of the machine take the screws loose that hold the front cover on and check to see if the uptake sceen is clear.
Jan 24, 2009 | Bissell 8910 ProHeat Clear View Upright...
Eureka Capture Vacuum
Either the filters are clogged, the hose has a clog in it, or the dirt inlet down by the brush roll is clogged. Pull the hose off and see if you have suction at the end of the hose, that will tell you which way to look for a clog.
Feb 18, 2008 | Eureka Capture Upright Vacuum Vacuum
Cannot shut vacuum on hose
Will the main unit operate if you switch to manual operation. If so, then it could be that the PC board has a stuck relay and you will have to replace the PC Board. Could be the switch inside the handle. You take your hose to your local dealer and or someone that you know that has a beam system and plug it in and see if it works or not. If it does, then it is in the main unit, if it doesn't. then there is a problem with the hose or switch asm.
Nov 21, 2007 | Beam Industries 2775 Serenity Plus Central...
Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum Logo
63 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
