Question about LG WM2496H Front Load
LG wm2496hsm Really noisy and LE code
I have a LG wm2496hsm Washing machine and get a loud whining sound from it while it spins at high speed. After 10 min or so i get the LE code. I replaced the Stator Assembly and still have the same issue. the drum spins freely and with the rotor off it does not make any noise. Only when i install the rotor and spin the drum does it make noise.
  • Ted Almeida
    Ted Almeida May 08, 2012
    I have the same exact problem. What was your solution?
  • 5 Answers
SOURCE: LG washer wm1832c
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly (#6501KW2002A) and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Posted on Dec 08, 2007
SOURCE: LG WM 1832CW
if your getting LE code on your LG washer check if your hot and cold water is hooked up right
Posted on Jan 28, 2008
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
  • 8 Answers
SOURCE: le error code
IE means that it is taking too long to fill up.
Posted on May 28, 2009
MNTECH
  • 1543 Answers
SOURCE: I have an LG Tromm wm1812cw washing machine and
With a 10 year warranty on their direct drive washer motor, eliminating a clutch or transmission, those enerty star LG's generally preform very well. (one of my customers runs 10 loads a day, 365 days a year in his)
Sounds like the shaft may have seperated from the three spider arms which actually turn the drum. To remove, you may have to grind end of bolt off motor shaft to facilitate dissassembly. It's a rather involved process. Prevent future mold and mildew issues by cleaning out the drain filter and then using a front load washer cleaner on longest, hottest cycle with no clothes (like ahfresh or washer magic, or whirlaway hot tub cleaner, to name a few.) then use not more that one tablespoon of HE detergent and a max of a teaspoon of fabric softener (if you use it) per load, as these machines are using very little water. (when you split the tub to replace the drive spider, use a pressure washer to clean out the inside of the outer drum and the back side of the inner tub) BTW, I have not found any reason to not stick with my LG washer and dryer. My seven year old set worked many a load, and still works great.
Posted on Sep 02, 2009
WHAT IS THE SYMPTOM "LE"
A common reason for an LE code is choosing a high spin speed on a bulky/ very heavy load. Try a cycle with a lower spin speed. If you still get the LE code, especially if it does not even do the wash tumbling, then replace the Hall sensor on the motor.
Oct 19, 2012 | LG WM-2277HW Front Load Washer
GETTING AN ERROR CODE - LE ON MY WM2277HW
Feb 01, 2011 | LG WM-2277HW Front Load Washer
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
What does LEstand for on the washer machine??
LE stands for Load Error. You may have a bad hall sensor, but more likely have an off balance or very heavy load which you were trying to spin at a high speed. For heavy / bulky items, use the low spin speed. After the cycle, you can power the machine up again and just push the spin speed button until the next higher speed shows, then push start to get a 14 minute or so pump and spin only cycle if you want to spin the load out a bit more.
Jun 14, 2010 | LG WM-2277HW Front Load Washer
It makes a loud whining noise when it is on the spin cycle. Functions ok, but sounds like it is a jet engine...
Hello there: Here is a extensive list of things to look at and hopefully this will be very helpful for you Washing machine is noisy It's very difficult to advise on a noisy washing machine because you often can't describe noises accurately enough. People can describe the same noises quite differently. Please visit the following link for a detailed list of ways to help with your noisy washing machine. http://www.washerhelp.co.uk/diy-repair-help_2.html#cl_q4
Dec 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LE code on lg washmachine
The LE error code means that you have a motor problem.  The high pitched noise means that the motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to replace the sensor.
Jun 06, 2008 | LG WM1814CW Front Load Washer
Motor whine w/ agitation & no high speed spin
try undoing the pump assy (just unclipp and move it aside) no need to disconect hoses yet. tyspinning now, if quiet then theres csomethin in the pump, you may get lucky and be able to pull whatever it is out!
Mar 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Motor whine during agitation & won't spin at high speed LSQ9200PQ
check to see if the tub has any side to side play to start then pull the motor and check the coupling the clicking is whats confusing
Mar 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud winding sound
that's normal should sound like a lear jet engine cranking up load whining sound is that what your hearing mines been doing it for about 9 years high speed spin is 800 rpm let me know if that's not the sound besides the control bd not much there to go wrong
Dec 20, 2007 | Frigidaire Affinity ATF7000EG
LG WM1812CW PROBLEM
Just had this same problem on my LG wm1832CW machine. Sensor assembly was replaced and all is well..
Simple and fairly inexpensive to replace.
Oct 28, 2007 | LG WM1812C Front Load Washer
LG WM2496H Front Load Logo
81 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
