Question about Microsoft Windows XP Home Edition
Network conection how do i make my own ip address
  • 3 Answers
Property out your network conection and change from dhcp to static and put in your ip and save and exit done
Posted on Jan 08, 2008
I have by cannon 6570i moddel ihave continew error {chek the network conection chek the tcp ip the defalt key is curruptedor invelid}
1) Select the following service mode COPIER>TEST>NETWORK>PING, and select PING.
2) Enter the IP addressof your PC using the numeric keys on the control panel, and press OK.
3) Press the start key.
- OK is displayed if Ping succeeds, but NG is displayed if it ends in failure.
Perform this procedure only when connecting the machine to networks.
If the machine fails to be connected to networks, any of the following causes is probable.
a. Connection failure between networks and the machine
b. TCP/IP setting failure of the machine
c. User network failure
d. Main controller PCB failure
The detailed check methods are as follows.
Checking with Loopback Address
you can check whether TCP/IP settings of
the machine are appropriate by executing Ping with this address.
1) Enter the loopback address (127.0.0.1) in PING.
- If NG is displayed, check TCP/IP settings of the machine again, and re-execute Ping.
- If OK is displayed, perform the next check.
Checking with Local Host Address
The local host address is the IP address of the machine. Since the local host address returns in response to the network controller by executing Ping with the address, you can check whether the network controller (main controller PCB) is in a normal condition.
1) Enter the IP address of the machine in PING.
If NG is displayed, take the following actions, and re-execute Ping.
- IP address error of the machine: Check to see again if the IP address settings of the machine are appropriate. Ask the system administrator whether the allocated IP address is valid.
- Failure in the main controller PCB: Replace the main controller PCB
If OK is displayed, a cause may be user's network environment. Inform the system administrator of the current situation, and ask for measures.
Apr 16, 2011 | Canon imageRUNNER 5570 Copier
Router wont conect to network
Make sure your router is using the same ip subnet as the network.
Your router may be preset with a certain subnet and be set to hand out IP addresses via DHCP. If you are on a business network - you want the network's DHCP to hand out an address to the router... or you can configure a static IP range on the router that matches the network.
Dec 07, 2010 | Belkin Computers & Internet
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation...
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Mar 18, 2017 | OKI Computers & Internet
Conect to network
you have to setup in printer menu option
network settings
-> TCP/IP settings
-> IP address
-> subnet mask
-> Gateway address
and ping the ip of pirnter form pc and install the driver .
Jan 28, 2010 | Office Equipment & Supplies
Wifi signal canot conect because of DNS problem
see pal.for this you do require ip address settings by that i mean ip address,subnet mask and default gateway.if you do have these settings then the dns address can be used for static ip address primary = 4.2.2.2 & secondary = 4.2.2.3
take care
Jul 10, 2009 | Computers & Internet
I cannot conect with the default ip for the WGPS606 netgeat print server!?
Check the IP address of your computer and see if it's on the same range of the IP address of the printer server.
Ex. print server IP: 192.168.1.4
Your computer must have 192.168.1.XXX
Note: X can be any no. from 1 to 254
To assign an IP address on your computer:
Start > Control Panel > Network connection
Go to the properties of the local area connection then click on TCP/IP tab.
You can now assign an IP address on your computer with the same range of the print server.
Jun 27, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Printer printek web password
you can access this networked printer by their IP address
just connect through printer's IP address and you will get your printer access...
Mar 27, 2008 | Office Equipment & Supplies
Will not connect
If the connection is correct, make sure that the tcp/ip settings on your pc is set to OBTAIN IP AUTOMATICALLY. There might be a STATIC ip set on your adapter.
Mar 13, 2008 | Dell 1450 (D1450U) Wireless Adapter
Network
hii you conect net server pc . all pc conect in switch ..then your name all pc diffence .. and net conect server pc then go net conection dailbox properties ..networking ....enabil network conection then so server pc auto ip address....apply ok  done
Jan 08, 2008 | Computers & Internet
Connectivity
ok, clicking repair is a stupid setting that windows puts in as when you click it it immediately returnsyour pc's ip address to a windows default ip address which you router cannot read and therefore disconnects you. Go to your network adapter properties, right click on task bar icon on go to network connections and right click>properties TCP/IP line and click properties again then select if not already 'obtain ip address automatically', then ok it and close windows. If you are connecting through a router you need to get into the set up menu of ypur router by typing the router ip adress in your web browser(refer to manual for the address)and look for the conections menu and ensure your password and username is correct and make sure DHCP is enabled so as to give your pc an automatic ip address
Jun 24, 2007 | NexxTech NPCINIC Network Adapter
Microsoft Windows XP Home Edition Logo
20 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
