How long do i have to hold the buttons down to reset the lamp timer on the mitsubishi hc1600?
SOURCE: lamp timer reset
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the < > and POWER
buttons simultaneously.
SOURCE: reset the lamp timer on PJ506d
Here's the manual
www.aboutprojectors.com/pdf/viewsonic-pj506d-manual.pdf
On page 24 in 'Advanced Mode', it tells you how to re-set to factory settings, and that will probably include zeroing the lamp hours.
If not, there seems to be nothing else there.
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
SOURCE: I have a Mitsubishi X500U projector which, after
As you replace the lamp and reset the timer it should work.But if its not working then there are few reasons.The lamp door switch/lever is not closed properly or its loose.Check that.If its ok,then other possibility,the replacement lamp is working but its not compatible to your tv.On some tv models they dont detect compatible lamps.They see only original lamp.If that is not the cases then other possibility is that the lamp is faulty.
To get replacement lamp online there are few online sites.
Please click on this link directly:---There are 2 types of lamp.one is original and one is compatible.the original is costly.see both.
http://www.partstore.com/SearchModel/Mitsubishi/Mitsubishi/X500U.aspx
There is one more link:--- Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation
http://www.superwarehouse.com/Mitsubishi_Replacement_Lamp_for_S490U,_X500U_and_X490U/VLT-X500LP/p/110321
