I recently installed a new elec. baseboard heater with a wall thermostat in a new addition. i wired a 220 tstat. there were 2 red line wires on the tstat. there were 2 black load wires on the tstat. i put a hot line on each of the red lines (l1 l2). i on the black i wired on a white on one and a black on the other to the heater. i have power to the heater when the tstat is turned up and none when it is turned down. the problem is the heater doesn?t make heat. . can you help me. thanks GG
  • 43,501 Answers
When you checked across the black and white at the heater did you get 220v? If you do, then the heater is bad or the high limit is kicked out, check it out to see if it is open (no current will flow through it).
Posted on Nov 14, 2009
Testimonial: "Thanks! That worked. Turned out to be a bad heater. "
The thermostat on my electric baseboard heater has a red and black wire out the top and the same on the bottom. The electrician ran the power wire from the box to both red wires, one on top and one on...
If is 120 volt heater.The thermo can use 220 or 110 volt.The elec is only using the 110v half/side of therm.Should be ok.Does it work?OK to leave blacks unused.
Mar 16, 2010 | Fahrenheat Electric Hydronic Baseboard...
Reinstalling a baseboard thermostat on wall. two red and 2 black wires in box in wall, plus a connected ground. Older model Honeywell thermostat, niot mercury, with only 2 black wires. Tried several...
baseboard heaters are usually line voltage thermostats. the wire in your box sounds like a 240 volt circuit. either the 2 blacks or the 2 reds and wire nut the others. I dont know if they need to be connected to each other, not sure where they go or what they are to
Dec 16, 2009 | Honeywell Heat/Cool Thermostat
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
No i didn't. I need instructions for wiring a
you have baclk and red wire supply and a black and red wire to load (baseboard).
your switch will have 2 black and 2 red.
connect blk supply to 1 black on switch ( it doesn't matter which one)
connect red supply to 1 red on switch
then
connect black from baseboard to black switch
connect red from baseboard to red switch
if multiple baseboards that have several loads at thermostat then just connect baseboard blacks together and reds together before connecting at switch.
Oct 17, 2009 | Heating & Cooling
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if ur are replacing the heater and it was originally 220/240 ur wiring should b ok but to b sure trace the line wire back to breaker panel and look at breaker the white and the black should b hooked up to separate breakers if the white is hooked up to a ground bar usually on the inside side of the panel and the black hooked up to breaker ur line is 110/120 and will cause problems when hooked up. if the lines r 220/240 than red can hook up to white and black to black
Sep 25, 2009 | QMark FBE15002 electric baseboard heater...
Replacing a non-programable thermostat for electric baseboard heater with model CT410B. This is a 4 wire thermostat replacement for a previous 2 wire. Directions indicate that I can do this. I connect...
If you take thermostrat back off and connect the wires together will baseboard heater get hot. If not you may have bad heater. If it gets hot your new tstat may be bad. The way you have it wired is correct. Most line voltage tstats have a ground screw. Your 's may not but will work without one .
Jan 23, 2009 | Heating & Cooling
Wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Dec 14, 2008 | Fahrenheat Electric Convector Baseboard...
Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
How to wire 1 plf 1504d heater
I have the solution, finally after looking for 2 days.
First off, I couldn't quite put it all together based on what I was reading. I finally tracked down the Fahrenheat web site (www.fahrenheatpro.com). And called tech support (800) 452-4179.
To wire 2 BB units to 1 tstat.
1. Use #14 wire for 0-12 amps, #12 wire for 12.1 to 16 amps and #10 wire for 16.1 to 24 amps.
2. I have a 12/2 wire going from the tstat to BB#1 and another 12/2 wire going from BB1 to BB2.
3. Onthe left side of the heater, you will have 2 sets of black wires tied together with a nut (on right side it's 2 sets of Black/Red wires). You can use either side of the heater. For the purpose of explaining this, lets use the left side, 2 sets of black wires.
4. Undo one of the sets of black wires (it doesn't matter witch), the other set will be left alone.
5. Take the black wire coming from the tstat and tie it into one of the black wires from the heater and the black wire going to the second BB unit. So you will have those 3 wires tied together with a nut at the 1st BB unit.
6. Take the white wire coming from the tstat and tie it into the other black wire from the heater and the white wire going to the other BB heater. Again, you will have 3 wire tied together here.
7. At the second BB unit, tie the black wire coming from the 1st unit to one of the black wires in one of those 2 sets of black wires. Again, only undo 1 set of wires at the 2nd unit, leave the other one alone. Tie the white wire coming from the 1st unit to the other black wire.
8. Make sure ground wire in grounded at the tstat and at both BB units.
Hope this helps...... If I was less clear than I hoped, call tech support and they will walk you thru it....
Kevin.
Dec 08, 2007 | Fahrenheat Electric Convector Baseboard...
Wiring on thermostat tl7235a1003
OK, here's my guess at this...I hope someone more knowledgable will confirm or correct me.
A line voltage thermostat switches the power to the baseboard heater. In other words, it's just like a wall light switch except it activates and deactivates based on the temperature.
I think your old model CT62 was wired exactly like a light switch. The hot wire to the light is broken then run to the wall switch and then back to the light so there's no neutral wire at a light switch box. This worked fine for your CT62 because it did not need power, it only needed to switch it.
The new model TL7235A1003 requires electrical power because it's programmable so you need both a hot wire and neutral wire at it's installed location. In addition you also need 2 wires leading to the baseboard heater so the thermostat can supply it's power.
I believe L1-L2 are to be connected to the hot/neutral wires, and the Load wires go to the baseboard heater.
If I am correct you will not be able to use this thermostat without some re-wiring.
Good luck.
Nov 27, 2007 | Ingram GMS90904CXA Heater
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
