Question about Garden
I've snapped the spark plug lead on my victa sss 201b and i don't know how to get to the coil to replace it?
  • 486 Answers
The coil is located under the recoil assembly housing, near the flywheel.
Here is a fix that may help if you have room to work with.
Strip off of the rubber part of the cable so that you can attach the wire portion with a '****' connector that would be used in repairing 12 volt wiring on an automobile. Then using black 'electrical tape', start taping the outer cable and cover the connector. This will keep moisture and the possibility of electrical shock from the connector area.
Posted on Nov 14, 2009
Why does my 2009 2.0 dodge caliber only fire on the front two cylinders the first time I start it up and after I cut it off and back on only the back two cylinders fire
Hi anonymous, the link below is a short youtube video on how to replace your coils....If you don't know which coils are faulty just pull a spark plug lead off a spark plug and plug the spark plug lead onto a SPARE spark plug, Now earth it to the CLEAN motor or body (make sure the spark plug is touching metal) Turn the motor over using the ignition, If the spark plug doesn't spark then replace that coil.....CHEERS..
https://www.youtube.com/watch?v=Qs7hw_BjAGA
Mar 27, 2016 | Dodge Cars & Trucks
What size spark plug does a Victa 4215 HXT use
Contact Victa customer support at his link. After they give you the spark plug number, go to Bunnings and buy one.
http://www.victa.com/au/contact-us/
Apr 04, 2015 | Garden
How do I replace the rubber boot on my spark plug lead victa mower
I have never seen just a replacement boot. You may have to replace the entire plug wire.
Oct 03, 2014 | Garden
Can't find EGR Valve. I know what it looks like but its not visible. OBD 2 Coder reading P0300 - Generic misfiring. However my 2004 Isuzu Rodeo has all NEW coil packs and spark plugs. Anybody else have...
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
I know for your car, the ps701 is useful.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Sep 14, 2011 | Isuzu Rodeo Cars & Trucks
It cranks but wont start. Checked for spark with the lead plug wire from the coil to the distributor cap. No spark. I changed the coil still no spark. I've been told its my fuel pump. But I've...
if you are sure there is no spark and you have replaced the coil,then the only other thing it could be is your spark control moduel.it works off your computer to tell your plugs when to fire..somettimes they go out only when they heat up and will start working again after they cool down,,but sometime they don"t give you any warning and just stop working all together.. would say you have a bad Spark Control Moduel.....it is pretty easy to fix, just make sure you use or buy the right tools to take it off , ask at the Auto parts store to get the right tool, and the right part..
May 26, 2011 | 1988 Honda Prelude
My ford focuskeeps missing if sparks on 12 AND 3 BUT NO SPARK ON 4 CHANGED PLUGS AND LEADS CAN YOU HELP PLEASE
This has a coil pack and four spark plug wires, correct? If so and you have replaced the spark plug wires and you don't have any spark out number four but you have spark on number one than you have a bad coil. You can remove the number four wire from the coil start the engine. Use. Test light connected to ground and place it near the opening in the coil that the spark plug wire goes into. You should see a sharp strong snappy spark. You may find that you have to hold the test light really close to the metal part inside the oil tower to see any spark. If this is the case you have a bad coil. Be careful when checking for spark. There is between 30 - 40 thousand volts generated but the merge is extremely low. If you get zapped it's going to tickle. Bit but it won't kill you. Good luck and let me know what you find.
May 26, 2011 | 2000 Ford Focus
I would like to get a manual foe a victa tilt a cut
where can i by parts for a Victa Line Trimmer????? The coil snapped.
Sep 11, 2009 | Garden
I disconnected the coil packs and after i reconnected them the car wont start back up, what can it be?
If the car starts before disconnecting the coil packs, it might be the ground connection, have it checked. Check also the connections and the terminals if they are loose.
Jul 30, 2009 | 2003 Nissan Altima
Jerking bad when driving replaced coil lead plugs ok coil lead sparking outside coil
Is it sparking between boots or is it from the boot to the engine? You need to use dielectric grease on the boot on the coil to stop leakage of voltage between coil towers, I can't find the 2006 laser so chose a model similar to that model. With the engine off and you pull the spark plug wires put a little bit of the special grease on your finger and put it on the inside of the boot of the spark plug wire at the coil and at the spark plug. Be sure to not get any on the spark plug metal tip or on the metal on the coil pack. When removing the spark plug wire from the coil and plug be sure to twist it with the engine being cold so that you don’t ruin the spark plug wires. This should stop the leakage, if not then you have a defective coil/ coil pack and need to see if there is a carbon track or a crack in the coil assembly itself, let me know if this helps and get back to me if you need more assistance.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/partlist_Ignition-Coil_190_R%7CGRPTUNEAMS__coil___
Jul 24, 2009 | 2006 Ford Laser
Garden Logo
309 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
