Change a battery in samsung yp t9
I have bought a samsung yp t9 off a friend and the battery life is down to around one hour.Is it possible to replace the battery myself
The battery isn't soldered in Its conected to the m/b by a 2 pin connector so easy to remove .
Posted on Jun 19, 2008
I believe it is soldered in. If you can solder you should be okay.
Posted on Mar 08, 2008
    Guru:
  • 120 Answers
Posted on Jan 08, 2008
My samsung yp-t9 says automatic test!!!HELP!!!!!!!!!!!!!!!!!!!!!!
Try pressing the menu and the record button together at the same time.This resets the yp-t9.I guess this should help.
Jul 06, 2009 | Samsung Yepp YP-T9 Digital Media Player
How do you put videos into the YP-T9 mp3 using windows media player??? Would I have to convert the videos somehow? I've been having trouble with this, please help!
Look sir.The yp-t9 can only play svi files.In order to put the videos into your yp-t9 you must hav samsung media studio and also the videos must be in either mp4,avi or wmv format.And then use Samsung media studio to put the videos into your yp-t9,samsung medai studio will convert the videos into svi format which your yp-t9 can read.
Feb 21, 2009 | Samsung Yepp YP-T9 Digital Media Player
Samsung YP-T9 problem
look buddy first u shud get rid of the shorting out on the usb connection.
then get to samsung.com and check the support page of ur product and start downloading!!
Jan 07, 2009 | Samsung Yepp YP-T9 Digital Media Player
I want to reset my samsung yp-t9
Complete Solution - includes fix for Bluetooth.
You will need to execute a number of steps to do this:
1 - obtain a copy of the latest firmware from http://www.samsung.com/uk/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=mp3others&subtype_cd=&model_nm=YP-T9&dType=D&vType=L&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=YP-T9
or (even better) - go to the international site and download a copy of YP-T9 V1.80.zip
2 - Reset - Power off the yp-t9 using A-B and MENU pressed together - hold down A-B and press the POWER button to enter the low-level format mode - press LEFT LEFT RIGHT RIGHT UP CENTRE DOWN - the yp-t9 will now reformat - power off using A-B and MENU together
3 - reload firmware - Power on normally and connect to PC as a USB drive. Move the two files you just downloaded (MUON.ROM and SYSDATA.BIN) into the root of the USB drive - Safely remove the drive - Power on the yp-t9 and allow it to re-install the firmware
If you want to restore Bluetooth functionality you will also need to perform the following steps:
4 - pop the four rubber plugs out of the back of the unit - with a small phillips screwdriver remove the four screws - insert your fingernail into the seam of the unit on both sides and pop off the back - gently (slowly) remove the battery taking care not to place any strain on the connecting wires - copy dowm the 12-digit number on the label under the battery (starts 0016xxx...) - replace battery, back, screws and plugs.
5 - using text editor create a file with the 12 digits (use upper-case letters where appropriate) followed by <enter> key - save it as BT_MAC_ADDR.TXT
6 - connect the yp-t9 and open it using Right click on Start and Explore - find the yp-t9 and drag a copy of BT_MAC_ADDR.TXT into the SYSTEM folder - Safely remove - power on normally.
Hope this helps
Chris
Nov 19, 2008 | Samsung Yepp YP-T9 Digital Media Player
Videos
Yp-t9 only plays svi files.First make sure the videos you have are mp4 or avi or wmv.Then open samsung media studio.If u dont have it then download it.After that put the videos in your yp-t9 using the samsung media studio.The samsung media studio should convert those files into svi format which can be read by your yp-t9
Oct 09, 2008 | Samsung Yepp YP-T9 Digital Media Player
Samsung Yepp YP-T9 Digital-video playback
Yp-t9 can only play svi files.First convert those mp4 files into avi or wmv files.And use samsung media studio to put them into your yp-t9.The samsung media studio will convert ai and wmv files to svi.Or jus try to convert those mp4 files with Samsung media studio.It converts sometimes.
Jun 07, 2008 | Samsung Yepp YP-T9 Digital Media Player
Problem of frezzing and non asistance for my samsung tp-t9
Look sir.The yp-t9 has a minor problem of freezing.When it freezes just press the rec button and menu button together this would reset your yp-t9.This will help.
Dec 07, 2007 | Samsung Yepp YP-T9 Digital Media Player
Freeze
Congratulations on the purchase of your T9 ! The T9 has won many reviews, and rated very high for value for $'s. Now, depending on how long this unit has been sitting since it's manufacture, all new units usually require a 'wake-up'. The initial wakeup charging is critical to the battery's life, so follow instructions carefully, re charging. Then, "re-set" the T9 (ie hold both 'Menu' & 'A-B' buttons together, for 3 secs to re-initialise the built-in firmware). This procedure will overide everything. If this gets it goin, then download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your T9 - your manual should explain how to do this. Always update your T9 with latest firmware when available (appropriate with your Windows OS), to eliminate any bugs in the firmware. If this doesn't resolve, then use the factory warranty to have it serviced by an approved Samsung agent. Good luck.
Jul 01, 2007 | Samsung Yepp YP-T9 Digital Media Player
Battery life cut down to 7 hours
The thing is, you recharge it too much. Because when you recharge it even though it still has battery power left, it tries to recharge it as much as if the battery was depleted. So, your battery overheats, therefore allowing you 7 hours instead of 20. And yes, it is possible to switch the battery.
Apr 12, 2007 | Samsung YP-T8 Digital Media Player
1,076 people viewed this question
 Grubhead
Grubhead
