Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
The eject key on both of my keyboards does not work. I have a MacBook Pro notebook running Windows7 in Bootcamp. I have attached an external keyboard to the notebook. Everything works fine except for the eject buttons. I have googled the situation and see that many others are experiencing the same thing. How can I fix this?
  • jbcastles Nov 14, 2009
    I did exactly what you suggested. There was no kbdmgr.exe under the startup tab. i doubled clicked on the kbdmgr.exe in boot camp file and nothing seem to happen. You are correct about the volume keys and the brightness keys not responding either. What other suggestion might you have?
  • jbcastles Nov 16, 2009
    I haven't heard back from you. Any other ideas?
  • 4,472 Answers
First off here are a couple things to make sure of...
The Eject key on Apple keyboards works in Windows only after you have installed the
Boot Camp drivers. See “Step 3: Install the Boot Camp Drivers for Windows” on
page 14.
You must be logged in to a user account to use the Eject key. The Eject key does not
work when the Welcome Screen is displayed.
Also are you aware you can eject any time through windows explorer?Standard windows keyboards have never came with an eject key. It really isn't that necessary in windows. If you still need assistance please let me know.
Thank you,
Lee
Posted on Nov 16, 2009
    President:
  • 1,462 Answers
I wonder if your volume and brightness keys are working under windows.
Is it just the Eject key that is not working under windows?
Double Check to see if the file Kbdmgr.exe is getting loaded in Windows. The way to do this is to go to the Start Button and Select Run. Type in Msconfig and click on OK.
This action will open up the window titled System Configuration Utility. Select the Startup tab.
Ensure that there is a Check Mark placed next to the filename kbdmgr.exe. If a check mark did not exist then place one in the square and reboot computer and the eject key should work.
If a check mark exists then hit OK and get back to the Windows Desktop.
The next step is to manually run the Kbdmgr.exe file.
Go to C:\program files\boot camp and double click on filename Kbdmgr.exe. This will execute the file. Try using the Eject button again and see if it works after that.
Please leave me comment, if you still have problems, i will suggest you alter nate solution
Thanks for using FixYa!
Rnj VINODKUMAR
Posted on Nov 14, 2009
  • Vinod Kumar
    Vinod Kumar Nov 14, 2009
    If the Volume and the brightness keys doesnt work, then it must be due to the bad keyboard..There must be patch cord that runs from the special keys such as brightness and others to the motherboard, if this cord is loosened, then the apecial keys doesnt work..
    If brightness keys works then we can stop with the kbdmgr file,since this doesnt happens this must be a hardware issue..
    Have you tried these keys in Mac OS, does this keys works with Mac , if so we can conclude with hardware issue, you should remove the laptop keyboard to solve this issue..
    Please try these and leave me comment and i may help you
    Rnj VINODKUMAR
  • Vinod Kumar
    Vinod Kumar Nov 16, 2009
    I had written my comment on the same day itself...Refer the comment post..
    Please accept this solution, if you find this useful later..
    Thanks
How to eject a disk from my mac pro book
the key at the top right corner of the keyboard with the triangle above a line symbol is the eject key.
Oct 28, 2014 | Apple MacBook Pro Laptop Computer with...
Where is the eject button
There should be the key at the top right of your keyboard on your MacBook Pro. The icon looks like a triangle with a line under it.
Feb 17, 2014 | Apple MacBook Pro Laptop Computer with...
Macbook white keyboard keys 5, t, g, ?, ' stopped work
Most likely keyboard is dying! Try connecting an external USB keyboard and use the keys not working on the other keyboard. If they work then it means that you have a faulty keyboard.
Any liquids spilled on the keyboard ?
Oct 20, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have macpro 13inc.my problem is my disc is not working with the eject is not function.so still my dish is inside of my disc unit how can i remove manually pls. give me instruction properly thanks lot...
Thanks for contacting Fixya Support.
With the Macbook Pro 13" having a Superdrive or Combo optical drive, you are dealing with a slot-loaded drive. As a result, if you have a disc that is loaded into your optical drive, which will not eject, then there isn't a manual way to remove the disc without causing damage to either the optical drive or the disc itself.
In most cases, of a potentially stuck disc in a Apple notebook's optical drive, a visit to your local Apple Retail Store Genius Bar or local Apple-authorized service center would be highly recommended.
With that noted however, here are some troubleshooting steps to try from the Mac OS X side first before having to take that step and visit an Apple service provider:
- CD DVD EJECT -
- - Reboot your Macbook Pro 13"
- - Hold down your Media Eject key on your keyboard pad prior to the Apple Chime starting.
- - Keep holding the Media Eject key down while your Macbook Pro 13" boots up
- - The disc should eject before you reach your Desktop
- - When it does, simply release your Media Eject key.
If that does not work, try this:
-EJECTING DISC USING TERMINAL-
From your Desktop:
* Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
* From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
* Locate and open the Terminal application.
* At prompt, type: drutil eject and press the Return key on your keyboard
This command line should eject the disc from the drive, unless there are mechanical issues with the drive.
If neither of these steps work, then I would be remiss as an Apple Certified Tech, if I did not recommend you proceed to take your Macbook Pro 13" in for service.
I hope this helps.
Best Regards,
-Mactechtrainer
Aug 26, 2010 | Apple MacBook Pro Notebook
Keys not working
First off, you need to determine whether the keys themselves are faulty, or whether you just have your system set up to ignore them.
Go to Apple Menu / System Preferences / Language & Text (this is on Snow Leopard, on Leopard I believe you have to look under International). Turn on "Keyboard and Character Viewer" and "Show input menu in menu bar." Now on the Menu bar, you will see an icon of a box with an asterisk in it. Choose "Show keyboard viewer." Now type the arrow keys and see if they blink on the keyboard viewer. If they do, there is nothing wrong with your keyboard; you just have somehow set those keys to have no effect (and figuring that out is another issue). If they do not blink, you have a hardware problem in your keyboard that will require keyboard replacement.
Services like laptopkey.com will NOT help you, as they sell only key CAPS, and the problem is in your key electronics.
A MacBook Pro keyboard is NOT a user-replaceable part.
May 05, 2010 | Apple MacBook Pro Notebook
Cursor and keys are unresponsive tryed 2 check if it was number lock witch its not
There has been a known issue with the first key (any key) of a Macbook Pro, not responding when typed and Apple appears to have addressed this with this software update for the Macbook and Macbook Pro:
Run the Macbook Pro Software Update v1.1 and the Macbook, Macbook Pro Keyboard Firmware update v 1.0 per this link:
Keyboard Issues with Macbook Pro
Let me know if this helps.
Regards,
-Mactechtrainer
Mar 24, 2010 | Apple MacBook Pro Notebook
NewTouch Keyboard 200 function keys do not work on a MacBook Pro running 10.5
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the keys by selecting the Key to be changed.
Hope this will help some. Bud
Oct 10, 2008 | Logitech USB (967199-0100) Keyboard
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
32 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
