Question about RCA Universal Remote Control
I have lost the code for my RCA Universal Remote. It is not working on volume / channels.
    President:
  • 1,335 Answers
Check
http://www.thompsontv.com/rcarc.html
You should be able to reprogam your remote using the instructions and the codes at the website.
Please rate this solution. Thanks.
Posted on Nov 13, 2009
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
I lost the remote and can no longer change the input. The only buttons on the tv are power, channel up and down, and volume up and down. I have also tried changing channels past 0 and nothing is working. I...
Hello
It will be best for you to buy its original remote control. Universal remotes may also work with it, but some functions may not work properly. You can buy it from the Authorised Service Center for Toshiba at your town. Just give them the exact model number of you TV set [which can be noted at its back side]. They will give you the exact original one.
RCA RCR 311B model universal remote have setup codes for Toshiba. You may also try this remote. The codes are:
1047, 1071, 1103, 1105, 1108, 1159, 1163, 1178, 1188, 1190, 1191, 1196, 1211
I strongly advice you to buy its original one. OK.
Sep 04, 2011 | Toshiba 27AF45 27" TV
I have a Quasar tv/vcr combo, model VV2007, I have no remote and bought a RCA universal remote and none of the 3 codes work, the most I can get out of it is channel and volume, I need to add channels but...
Sometimes the universal remotes do not compromise fully with certain models especially with combo models.
So you might a different type of universal type to connect with the Quasar codes, but it is ideal if there is the model mentioned in the manual of the remote.
Volume and channel working is what is most important and should be considered good enough.
Sep 14, 2010 | Quasar VV2007 20 in. Combo
I LOST MY PROGRAMING INSTRUCTIONS AND CODES FOR MY TV THE MODEL OF MY UNIVERSAL CONTROL IS RCR4358 ITS A RCA
The code list is located at the following website: http://www.revoxremotes.com/Remotes/RCA_R55L8_Codes.pdf
Find your TV and hold the TV button on the top left. While holding the TV button, enter in a 4 digit code (they should be in the 1000's) - then release the TV button and try the channels or volume up or down
EXAMPLE: TV(1047) release TV button
- try all 4 digit codes associated with your TV
- once the code is entered, try it by clicking channel up or down
- hope this helps, this can be frustrating
- If the remote responds, stop trying codes, your remote is programmed
- WRITE DOWN THE NUMBER FOR YOUR TV WITH A SHARPIE ON THE REMOTE ITSELF THIS WILL PREVENT FURTHER WASTING OF TIME
Feb 06, 2010 | RCA 4-in-1 Universal Remote Control
I was wondering some codes for a RCA tv/ vcr combo
have a old rca television with a build in vcr. connectec a cable box remote works only for volume and channel but power button does not work, with remote was set and stop working call cable company and was told to contact rca to recieve codes for television
Sep 30, 2009 | Philips Universal PH301S Remote Control
I lost the manual to my universal remote control rca model number rcr461 .i need the code to vizio t.v ....
A manual does not exist for RCR461. Sorry.
http://66.77.167.109/rcaaccessories/
LG code 1196 works with some RCA Universal remote for power and volume.
Dec 24, 2008 | Televison & Video
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
Lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Press and release the TV button
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
If you want a hard copy with codes for all TVs.
Aug 29, 2008 | RCA Universal Remote Control
Ilo TV codes
Here are two more codes you can try they worked on my RCA 600M Universal Remote:
191 or 208
they both worked for the volume and channel up and down, I am still looking for a code that will get me to the menu, on screen info and allow me to change from TV to ANT1 ANT2 and Composite.
May 23, 2008 | iLO V27DMBX Television
Televison & Video Logo
70 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
