Question about RCA Televison & Video
I have a 52" RCA HD TV Monitor. It has developed a problem with a ringing noise that comes off and on. I do not know how to get rid of it. It makes me sick to my stomach. Help me please
  • jan4joe Nov 14, 2009
    The parts place that you recommended has not heard of my model. It is D52WOB. My TV has a loud ringing noise off and on.
    I WILL PROBABLY HAVE A REPAIRMAN COME OUT AND CHECK IT OUT.
  • RCA Master
  • 19,396 Answers
Hi.
The cause of the noise depend on the TV model.
Often an high pitched noise can be caused by a defective fan bearing inside the TV.
The color wheel is a part that can also make high pitched noise.
If noise is not caused by a bearing, but it is on speaker, then you have to replace the board that is hosting the audio circuit inside the TV.
The problem is fixed disassembling the TV, locating the source of the noise and replacing the part.
Parts for most models here.
Posted on Nov 13, 2009
  • Ginko
    Ginko Nov 14, 2009
    You did not even give me the model, I listed the problem cause for different model.
    Now that you gave rating to solution the problem will be passed to a different expert.
    Good luck.
  • 10,865 Answers
The high tension transformer rings for several hours before the monitor dies all together. Sadly now you will be sick for a different reason... And I hate to be the bearer of bad news. The only way to get rid of it is to replace the high tension transformer. The problem there is that the cost is prohibitive, and really not worth it compared to the relatively low cost of replacing it. Regards, Joe
Posted on Nov 14, 2009
RCA 52" hooked to cable, can not see their heads. Is it because of HD. Do I need an HD cable from box to tv?
You can put it in wide screen format. On my remote I have to push TV then the right button a few times (right of the OK in the center) and it puts it in widescreen mode. My tv sayes RCA HDTV MONITOR on the front. I hope this helps.
Mar 06, 2010 | RCA Televison & Video
I have a RCA Home Theatre, gemstar guideplus gold. I think it is a 52" rear projection. I just want to know is it a HD TV?
It does not have an HD or ATSC tuner. But it does have HD resolution inputs - ie HDMI and component video (RGB) so effectively it is HD
Nov 24, 2009 | RCA D52W19 52" Rear Projection Television
POWERS OFF
CP150, CP114 and CP120 Capacitor repair kit at www.tvrepairworld.com should repair that issue. The kit contains the parts and the CD with instructions.
Nov 03, 2009 | RCA D52W23 52" HDTV CRT TV
TV picture went out.
power supply problem check capacitors...caution
high voltages..large capacitors retain nasty charge for a long time.........
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Going to an ant on my TV
NO!!!!!!! You are HD Ready if your TV is HD if not then you will need converter box to recieve channels from a antenna,.
Dec 30, 2008 | Televison & Video
52 inch won't come on
did the loud noises come from the speaker or from the back of tv?
Dec 12, 2008 | RCA HD52W58 52" TV
Powers on and then right back off
Try and clean the two filters on the tv this should be the first thing to do.
Feb 01, 2008 | RCA HD52W58 52" TV
Hd61lpw42 rca tv
I also have an issue w/my RCA rear projection TV making a piercing sound. My TV does not do it on the HD channels, but does make the noise on the regular cable channels and on On-Demand as well.
I
Dec 27, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
