Question about Kenmore 63792 Microwave Oven
Need a mounting template for kenmore microwave model 665.60657000
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave has loud buzz and does not work
It's probably a shorted high-voltage diode or magnetron, but there's some chance it's a bad high-voltage transformer.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view and order parts by entering your model number here: http://www3.sears.com
Posted on Nov 18, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Kenmore Microwave Model #665 6861 1891
F6 appears to be a relay failure on the main board, but it may be a door switch or door switch mount.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
  • 3 Answers
SOURCE: kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Posted on Jul 01, 2008
  • 25 Answers
SOURCE: microwave KENMORE code error F6
F6 is a relay failure
Posted on Jan 14, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: where can I find the paper template for wall
You may be able to download the installation instructions from the Sears parts site.
Just enter your full model number there.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will also have the installation instructions inside.
If yours is not listed there for free, or does not contain the template, you would have to order it through the
Sears parts site.
Posted on Sep 11, 2009
Testimonial: "The part I need has been discontinued and the Sear's website confirmed that it is not available any longer."
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
I want to install a new microwave over the counter microwave that uses the existing mounting screws, vents, template and whatever. I don't want to have to do anything but disconnect and remove the old
you must ask to the supplier for the dimension and based in the models specifications. Contact them via ONLINE chat and get the support for better performance.
God bless you
Nov 18, 2013 | Microwave Ovens
Need Installation 'Paper' Template for MMV4184AAW Maytag Microwave
see the video
and proceed according. God bless you
Apr 02, 2013 | Microwave Ovens
Can you provide guidance on how to install this microwave? Trying to decide if I should pay $120 for the store to install.
Installation of an over the range microwave is not a very difficult task as long as electrical work to provide power is not needed. If no outlet exists then an electrician will be required.
Tools that may be needed for the installation include a cordless drill, drill bit, measuring tape, masking tape, stud finder, razor knife, pencil.
A template is commonly provided for mounting hole locations that need to be drilled in the cabinet. These holes are the top mounts.
An additional template for the wall bracket is normally supplied as well. Here you will need the stud finder, it is important to locate the studs and mount the wall bracket to them.
The wall bracket serves as the bottom mount and aids in the final mounting of the microwave.
Depending on the oven's size and weight a helper may be needed to complete the installation.
Remember to be safe first and seek advice/help with any step you are unsure about.
Good luck.
Jun 27, 2010 | Whirlpool WMH1162XVS Microwave Oven
Wall template mount for ge profile microwave
You can may be able to order that by looking up parts by your full model number here.
Jan 10, 2010 | GE Profile Over-the-Range Microwave
Hi there, I'm installing an LG LMV205SW OTR Microwave and the four holes for the mounting plate do not coincide with the two wall studs that are behind the microwave location. Can I sink a couple of extra...
Consider the studs as I I add 2 2x4's like in an H with second 2x4 below the cenre bar in the H adjust both to the spaces needed for your mounting crews if it came with a template use it....I am not a carpenter but It Is what I would do
Dec 29, 2009 | LG LMV2083SW Microwave Oven
When installing over the range microwave does template need to be removed
the paper template that they send to mark for mounting instructions? yes...another template you're refering to?
Oct 25, 2009 | Bosch Microwave Ovens
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
Oct 23, 2009 | Jenn-Air JMC9158AAS Convection/Microwave...
Where can I find the paper template for wall mounting a used Kenmore microwave Model 665.60652
Sears parts site.
Sep 09, 2009 | Kenmore 60652 Microwave Oven
Template
Glad to hear it worked out.
Dec 30, 2008 | Kenmore 62702 Microwave Oven
Kenmore 63792 Microwave Oven Logo
322 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
