Question about Sterling Home
I have a new sterling 1.6gpf toilet can I increase the amount of water in the bowl. Every time or almost everytime, waste sticks to the bowl and I have to brush it loose.
    Problem Solver:
  • 5 Answers
If you raise the water level in the tank it will double flush. I suggest you change out the toilet to a Toto or Kohler class five flush action.
Posted on Nov 14, 2009
Why the Water drains out of the bowl once flushed and refilled
Water will pull from your toilet if you drain below your toilet is slightly blocked. Most drains in the USA are about 4 inches wide and will allow quite a large amount of waste to pass through. Any blockage will force more pressure from the drain to the toilet and pull more water from the bowl. Reversed effect you will get bubbles that push through to the inside of your toilet. might try some toilet waste line dissolving cleaner..
Hope this helps FixYa issue - Have a great night..
Mar 26, 2016 | Home
CAN THE TOILET BOWL WATER LEVEL BE ADJUSTED?
Not sure on that toilet but you can fill a water bottle with the desired amount of water and then stick it in the tank thus tricking the toilet to put less water into the bowl with each flush. If you want more water though I am not sure how to do it.
Jun 11, 2011 | Pegasus Technologies Two-Piece Round...
I just installed a new perfects. The pool of water in the bottom of the bowl is small, how do i increase the pool of water in the bottom of the bowl.
The toilet you just installed is a 1.6 gallon flush water saver and will not have the same amount of water in it that your old 3.5 gallon toilet had. The water level may not be able to be raised as this is the nature of the beast.
If you can raise the level it will only be a little and will be done in the tank area by increasing the water level in the tank. If the water level in the tank is at the mark provided it a done deal.
The amount of water refilled into the bowl is done by the tube that runs from the fill valve into the overflow tube of the flush valve so if you put more water into the tank more water will be put into the bowl but the bowl will only hold as much water as the trap weir will let it hold (what the factory has sit it at and is not changeable
Mar 07, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
Sometimes it takes several flushes to remove even a small amount of waste. Other times water spurts out of the toilet bowl when we flush. This is a brand new toilet and we are quite...
For now, just hold the handle down until everything goes down, common problem with low water use toilets, You may want to take this unit back and get another one.
Feb 13, 2011 | American Standard 2002.800.021 Champion...
Is there a way to adjust the amount of water in your toilet bowl in order to improve the flush?
There is only one way to do this and that is to increase the water level in the tank. To explain the flush valve in the tank fills both the tank and refills the bowl at the same time if the valve runs longer to fill the tank it will at the same time put more water into the bowl. Now having said that the bowl will only hold a set amount of water before it starts running out into the drain. If the tank water level is at the line marked in the tank it will most likely not do much good to raise the level beyond that point and if the toilet you have is a 1.6 gallon flush tank I am sorry but learn to live with it.
Feb 11, 2011 | Plumbing
How do you get more water to stay in the toilet once the toilet has been flushed
Hello. Increase the amount of water that stays in the tank and you will automatically increase the amount of water in the bowl. Joe.
4 thumbs up please.
Oct 12, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Increasing water in bowl
You really can't because of the design. Any water above the level now will drain off. Sorry
Nov 04, 2009 | Toto Toilet Onepiece Neorest 600 ...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Not enough water in the bowl
The fill valve probably has a float that surrounds the pole that extends from the bottom of the tank. The float usually has a metal rod that comes down with a clip to adjust the float. Move that clip up so that the float sits higher-this should add more water to the tank.
Jun 26, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Home Logo
302 people viewed this question
Top Sterling Home Experts
jmartin50
Level 1 Expert
Tim Whalen
Are you a Sterling Home Expert? Answer questions, earn points and help others
