Question about Panasonic PT-60LCX64 Television
A message keeps popping up saying I need to clean the air filter then the tv shuts off on it's own. It's a panasonic 60 inch projection
  • 460 Answers
There is a louvered air intake panel on either lower side of tv. there is 1 or 2 screws the filter is right behind that panel.. take it out and clean it with warm dishsoapy water and pat dry on a flat surface with paper towels then reinstall. your th will not come on till the panel is screwed back into place. there is a microswitch type sensor that makes sure that the screws are in place...goodday
Posted on Nov 13, 2009
  • Panasonic Master
  • 8,457 Answers
Clean the fan,or replaced it.Clogging with dirt.
Reset air filter
Page 58 of the user manual says that after cleaning the filter when the power is turned on, you will be given the opportunity to reply "Yes" to the question "Did you clean the filter". I suggest you go through the motions of cleaning the filter again, removing the necessary parts. Then replace the parts, turn the power on, and watch carefully for the message "Did you clean the filter".
Jan 06, 2014 | Panasonic PT-40LC12 40" Rear Projection...
Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Apr 25, 2010 | Panasonic PT-52LCX65 44" HDTV
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Air Filter Cleaning
Call the factory for an authorized servicer near you, your TV guy doesn't understand Panasonic...
If the lamp thermal sensor is active, the fans just keep running because it thinks the thing is hot (to save an expensive part from exploding). It does not give any error message.
Fan 1 is used for air filter detection. (It's essentially the same run-sensor type fan used in their stereos.) Fan 1 plug P2902 at the right side of the light engine board may not be making good contact or the fan is not running. The micro must get the proper feedback signal from that fan to keep it happy.
Good luck, Mark
Jul 23, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Pt-52lcx66-k multimedia projection hdtv - air filter needs cleaning
Good Day,
It sounds like your lamp sensor is defective. Change it and it should correct your concerns. I hope this helpful.
Jun 11, 2008 | Panasonic PT-52LCX66 Projection Television
Where is the air filter on my Panasonic PT50LCX64 TV and how can I clean it?
I have the same problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 05, 2008 | Panasonic Televison & Video
Reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-60LCX64 Television Logo
771 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
