Question about Ricoh Office Equipment & Supplies
Machine is Ricoh Aficio 1022. Will not function. Displays red crescent wrench sumbol and service code SC541.
  • gereboy Nov 14, 2009
    The problem has been remedied, thank you very much.
    Your help was prompt and effective. I hope the solution isn't temporary.
  • 350 Answers
First try to reset an error on Ricohs... Just enter Service Mode (Yellow Key, 1, 0, 7, Hold Stop Key until it gets into Service Mode), then Power off, wait 10 sec and Power on. If that does not work do this
Press clear (yellow button) followed by 1, 0, 7 then hold down the stop (orange button) till it enters service mode. Press on 'Copy SP' then key in '5810' and press '#' and then press on 'excute' to reset the service code. Then just turn the machine off then on.The problem may come back and if it does there is a problem with the thermistor. There is an update for the firmware for sc541 and sc542 codes. I think the firmware added a fuser idling time. Click the link and download the appropriate software required.
http://support.ricoh.com/bb/html/dr_ut_e/re/model/x1022_27/x1022_27en.htm
I hope this helps and good luck!
Posted on Nov 14, 2009
Service code "SC541" on A Ricoh Aficio 1015/18
that mean themistor is corrupted chang it first try to clean it if it does't work change it his position on fuser unit
Jan 11, 2011 | Ricoh Aficio 450 Copier
Functional problem sc 541 for richo aficio 1022 photocopier
SC541 = The melting temperature measured by thermistor is less than 71 C
The problem lies in the fuser:
- Thermistor fuser defective or incorrectly installed
- Fuser Lamp failure
Solution: Replace Fuser
Jan 05, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Jun 23, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Error sc548 aficio 1022 ricoh
Poor connection of the fuser, and the code will need to be reset in service mode.
Jul 17, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
169 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
