Question about Sanyo PLC-SW30 Multimedia Projector
No powers ups
The projector was on for about 3 hours then that went off, i turn it back on and that went off again after 5 min.i left it coll down and when i was trying to turn it back on i realise that the power indicator light is not indicated.what is the problem. thanks
  • kasturiranga Feb 25, 2008
    do help me in this issue as it was working fine and all of a sudden i am facing this problem. thanks
  • 27 Answers
Does the lamp try to fire up
check lamphouse and fan filter safety switches
Posted on Feb 26, 2008
How to reset lamp hour on lg bx327 projector
Here is a link to the manual in case yo don't have it:
http://www.projectorcentral.com/pdf/projector_manual_6082.pdf
However it doesn't include counter reset instructions that I could find!
I didn't find specific 327 instructions, but here are 3 different procedures for other units:
Turn the power off but keep pluged in. Press the buttons on the control panel in the sequence as below.
Press "Up Arrow", Press "Down Arrow", Press "Left Arrow", Press "Right Arrow", Press "Menu", Press "Enter".
Lamp time will be initialized
Posted on Mar 01, 2008
  • If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
    Posted on Oct 02, 2008
  • SOURCE:Lamp timer on Sharp XV-Z2000 will not reset
    • I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the "0000H" on the bottom left of screen...that's how mine worked today.
  • If/when you get it to work, please post back via comment to original question.
Jan 08, 2015 | LG BX327 3D Projector
My HD80 has about 700 hours, original bulb assembly, was working fine until I got curious and "activated" the auto off function while going through the menu. Now it will power up, lamp does not go to
Ensure a video source is connected to the projector (VGA, DVD, etc)
Unplug the projector to make sure it has completely shut down (not just went into sleep mode)
Plug in power and power on the projector (make sure video source is on first)
The projector should turn on and switch to the video source (manually select if not)
Once you can see the video source, push menu and turn off auto-off.
Auto-off should only work when the projector detect a video source is no longer present on the selected input. So if you are turning on the projector with no video source connected, it will usually turn off shortly after being turned on.
Nov 30, 2014 | Optoma HD80 Projector
How to reset lamp hour of panasonic pt lam1 lamp
hi,
Do the following for reset the lamp hour timer of Panasonic PT-LM1U
1. Power ON the projector. (wait for the display)
2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
4. Press and hold Enter button for approximately 3 minutes.
5. The LAMP RUNTIME will change to TIME RESET. (power off).
6. Turn off the power.
OK
Jul 18, 2011 | Panasonic ET-LAM1 Projector Lamp for...
Forgot the password, was in storage for since dec 2008. tried the initialization procedure out of the manual and . . . no change.
I just wanted to clarify a few things,
The initialize procedure is:
  • power on projector
  • press enter
  • turn off the projector by pressing
  • unplug the projector
  • plug the projector back in
Once the projector has been initialized the factory password is:
"up - right - down - down - left - up - right - down - left" and hit enter
This will allow to then enter in a new password
I hope this helps,
Magoo
Mar 07, 2011 | Panasonic PT-LB75U LCD Projector
I have a Optoma HD80 and the bulb has about 450 hours on it. I cleaned the projector, unpluged it for several mins and still turns off after starting. If the bulb has only 450 hours on it, why should I...
hi,
You have to check the bulb first. Its not the matter of how many hours you have used it. just check the lamp. may be it burned out. Its only a bulb it can burnout at any time. also check the lamp colling fan is working or not. if it is not working the same problem can occur.
ok
Feb 06, 2011 | Optoma HD80 Projector
Set wont turn on, Beeps.
Try Resolder all of the Big Diodes around power supply.
Feb 18, 2009 | RCA P52960 52" Rear Projection Television
Microtek cx6
I've had the same problem with my projector three times (usually whenever there's a sports championship). You just need to call optoma, get an RMA number, and ship it to them. Theoretically they'll fix it under warranty and send it back free.
May 02, 2008 | Optoma HD72 Multimedia Projector
Wil not turn on
Either your lamp is burned out or you had it unplugged for a while.
If you have had it unplugged for a while, plug it in, make sure the yellow power light is on, then wait for about an hour. Don't repeatly try to turn it on in the meantime. After about an hour or two plugged in,,,,, it should power up. Then reset your lamp timer through the menu.
Apr 02, 2008 | Toshiba TDP-T9U Multimedia Projector
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Sanyo PLC-SW30 Multimedia Projector Logo
85 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
