Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I need the disc that comes with the epson stylus nx400 printer scanner. I lost mine and it won't even recognize the new ink cartridges that I bought from epson without it. Please send me the computer disc at M.Hayes 2205 Pipelin Rd #4309, Cleburne Tx 76033. I will either pay by check or credit card. Thanks M.Hayes
  • 685 Answers
My epson stylus nx420 printer does not recognize the new black ink cartridge
I thing you need to call customer support try 0-800-090-3966 for more info
thanks
Sep 06, 2017 | Epson Stylus NX400 InkJet Printer
My Epson Stylus NX400 won't recognize any of the ink cartridge after I performed a head cleaning and nozzle check option. There are still ink inside and they are original genuine ink. What should I do?
Did you remove the ink cartridge when you did the head cleaning and nozzle check, if so, did you touch the copper circuit chip on the cartridge? . . The chip is normally what tells the printer how much ink is remaining in the cartridge and if it cannot read this, it may not recognise that the cartridge is genuine and still has ink remaining inside. . . .You can try cleaning the chip with a soft dry cloth otherwise you may have to install a replacement cartridge. . . See http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=106004&prodoid=63075469 for the User Guide showing how to replace ink cartridges for this printer.
Sep 19, 2011 | Epson Stylus NX400 InkJet Printer
How do i get compatible cartridges T069 to be recognized by the nx415 Epson printer?
i found out a site that offers cheeper compatible ink cartridges... try to check out this site: http://www.swiftink.com/Epson-Stylus-NX415-Ink-Cartridges-s/3544.htm. they do offer warranty should these inks dont work.. and they are safer to use because they do have quality control even thought its remanuctured.
Jul 14, 2011 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
My epson nx400 getting message cannot recognize ink cartridges its new out of box replaced magenta after only printing 6 sheets of paper i am using epson inks.
Have you taken out the spacer between the cartridge and its locater handle? Else just try taking the cartridge out and re-inserting. If this fails have you tried powering the printer off, waiting 20 secs, and truning back on.
Hop this helps.
Jan 25, 2011 | Epson Stylus NX400 InkJet Printer
I just bought an Epson Stylus NX415 and the it won't print because it says "cannot recognize ink cartridges". I install the ink cartridges that came with the printer, and they are in the proper order. ...
Sounds like you have either a defective cartridge but if both cartridges are not being recognized it's likely a problem with the printer.
Take it back to the store you bought it from for a refund or replacement.
Oct 25, 2009 | Epson Stylus NX400 InkJet Printer
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
Just installed Epson NX400 printer. Keep getting M88/69 "Cannot recognize ink cartridges" error. Tried re-inserting cartidges twice already and still same error. What next?
I found a solution to the same prolem that you guys have. I took the cartridges out and shook them horizontally, instead of vertically, with the large surface up for 3-4 seconds. Re-inserted them back in. Then I started seeing on the LCD "Recharging Cartridge". When it returned to regular copy screen, I turned the printer off and turned it back on. No more error message. It's been working for almost a day now. Try it to see if that works for you. Good Luck.
FYI. I just bought NX400 last Friday. The error message came on this morning.
Jan 01, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
129 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
