Hello I have following things and try to get output of my camcoder or dvd player or PS3 to my laptop screen
HP DV7 laptop -window vista 64 bit OS
Softwere :Windows Media center
External USB NTSC/ATSC TV Tuner (Dell) and driver is already
installed in laptop( Wave ATSC -
http://lumanate.com/aspx/sptwaveatsc.aspx,http://support.dell.com/support/edocs/acc/P128224/UG/intro.htm)
It has USB output and input can be following
Cable,antenna,S-Videoin,Composite video in (red,yellow and white)
Now using this i am able to see TV/Cable program to my laptop.
(connect cable wire to tv tuner card and usb output to laptop and start
windows media center and click on Live Tv)
i tried same thing with my sony hdr7 camcoder. but i m not able to see output at window media center - i check on channel 3 and others.
do i need to use other s/w or hardware to capture video?
I've had the same problem with two other unrelated HP input products in this area myself so I understand the pain. Media Center is not really well geared for nor is very friendly in the end user component input area. I'm assuming you've already tried playing a video file from your camcorder while setting up the Media Center input settings? Try a different software that will recognize your input card. Ideally, you should use any input software that came with the card itself from the manufacturer. Contact the manufacturer for a link to the original software bundle if you can't find it from their website or you may need to research your own replacement software solution for this product.
For more reading on this subject, check out this link: http://forums.techarena.in/mediacenter/767259.htm
